Camshafts
- kool4kawis
- live is just evil in the mirror
12 Apr 2012 06:27 #515373
by kool4kawis
Camshafts was created by kool4kawis
Will cams from an 83-85 GPZ1100 fit in a 81 CSR 1000 and if so are they a drop in or are modifications needed. I was told they would provide a decent boost in power but not sure if I would need 81-82 gpz cams or if any early to mid 80's gpz would fit. I am running 34's with pods and a custom exhaust so would I get the benifits of a slightly larger cam or is head work required. I'm not concerned with the loss of the tach drive as I run an aftermarket gauge set up. Thanks for any help!
- etbike3135
- Thank you received: 50
12 Apr 2012 08:20 #515380
by etbike3135
1973 Kawasaki Z1
18 years in dragbikes
Replied by etbike3135 on topic Camshafts
83/84 GPZ1100 cams are the ones you want. Drop in with a good pick up in power.
1973 Kawasaki Z1
- kool4kawis
12 Apr 2012 22:48 #515507
by kool4kawis
Replied by kool4kawis on topic Camshafts
thanks for the info
