- Thank you received: 2
push pull cables
- Roca
12 Apr 2012 03:46 #515367
by Roca
1980 KZ550-C2 LTD Custom
push pull cables was created by Roca
I was looking on eBay at cables and they have a push cable and a pull cable. They also have pull/push cables. So my question is, are the push and pull cables the same cables or not. I meed them both but want to make sure I order the right ones. Thanks.
- DiamondSkyBlue1000
- Thank you received: 40
12 Apr 2012 04:30 - 12 Apr 2012 04:32 #515368
by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic push pull cables
1980 KZ550C1 Parts Diagram
According to Kawasaki.com they are different. What makes them different is unknown to me.
Last edit: 12 Apr 2012 04:32 by DiamondSkyBlue1000.
- Powerstroke_fan
- Thank you received: 83
12 Apr 2012 09:38 #515391
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic push pull cables
I didnt think they were last time i bought one i dont remember specifing which one i needed. I think they will work on either.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
12 Apr 2012 09:53 #515392
by SPARKY47
1980 KZ500 B2
Replied by SPARKY47 on topic push pull cables
As long as the return spring on your carb bank (throttle) is in good condition you can use just the one cable.The two cables push and pull the throttle mechanism and the push cable is assisted by the spring.Saves you having to buy two cables.
1980 KZ500 B2
- ramtough_63
12 Apr 2012 10:20 #515397
by ramtough_63
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Replied by ramtough_63 on topic push pull cables
if I remember right the pull lenght and push length sre different. I olny run the pull cable it seems like when I put my cable n I had both the better looking on was too short and had to use the other one
It;s been a while so I may not remember right but I am pretty sure
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- Old Man Rock
- Thank you received: 225
12 Apr 2012 10:21 - 12 Apr 2012 10:22 #515398
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic push pull cables
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 12 Apr 2012 10:22 by Old Man Rock.
- RonKZ650
- Thank you received: 240
12 Apr 2012 11:47 #515422
by RonKZ650
Replied by RonKZ650 on topic push pull cables
The difference is in the elbow up by the throttle on your bars. The elbows have to be different lengths to enable each to be threaded in a decent ways. If both cables were the same, one would have to be threaded in all the way, then when trying to thread in the second one it could only be barely threaded because the first one would be in the way. Do you think it OK to have one threaded in 15 turns and one 2 turns? Then Motion Pro using 2 of the same cable works. If not, the cables are different, but as mentioned use the pull cable is all you need.
12 Apr 2012 12:34 #515428
That is the most succinct explanation I've heard yet. Every time I've installed the push and pull cables on my bike I've always appreciated that but never took particular note of it.
- Roca
13 Apr 2012 00:57 - 13 Apr 2012 00:59 #515531
by Roca
Replied by Roca on topic push pull cables
The reason I was asking is for this throttle from motion pro. My old throttle is all rusted from previous owner and he cut all the wires out. So I might as well keep it simple. So with this throttle I can use 2 of the same cables?
www.denniskirk.com/57549.sku?utm_source=google&utm_medium=cse
Last edit: 13 Apr 2012 00:59 by Roca. Reason: forgot link
- Jonny
- woot!
13 Apr 2012 05:50 #515545
by Jonny
'78 KZ 650C2 'Lila'
'71 Norton Commando 750 'Eadie'
St. Catharines, ON (Mostly, anyway...)
Replied by Jonny on topic push pull cables
I remember reading in some thread here year ago; some member was out for a ride, and broke the main throttle (pull) cable. While a agree that you really only need one (and at present I have a single cable!) it resonated with me somewhat that he was able to get going again by swapping out the push cable to the opposite position.
I am ordering two new cables with my next Z1 order. I guess its really not required, but it's a very inexpensive insurance policy.
Cheers.
Cheers.
'78 KZ 650C2 'Lila'
- bluej58
- Thank you received: 511
13 Apr 2012 07:22 #515550
by bluej58
78 KZ1000 A2A
Replied by bluej58 on topic push pull cables
Z1 sent me two of the same for my 1000 and they work fine.
When screwing them into the handle bar I needed to do them at the same time,
kind of like a dance :dry: , if you spin them both they miss each other because of the curve.
You'll see.
JD
You'll see.
JD
78 KZ1000 A2A
