I have a problem with my z750e it has been rewired and the idiot lights replaced with three leds highbeam neutral and oil pressure, the problen is when i am riding at night in a darkened area i can see the oil led is very dimly lit i have to squint to see it, now the led works properly when the ignition is switched on and goes out immediately when the engine is started and in the state of tune if i had low oil pressure the thing would have shat itself in an instant so i'm thinking possible trickle of power coming through the pressure switch?
any ideas?
1981 z750e1 gpz 750a1 tank and side panels 810 bore kit web cams mikuni bs34 vance and hines pipe
