Cylinder 2 not firing
- richrand
11 Apr 2012 16:47
I've got good compression and spark, but it's not getting fuel. I stripped, cleaned and rebuild the carbs, reseated a new set of manifolds with clean air filters. The plug is dry. I pulled the plug and hit the starter with the throttle open and there was no puffs of air/fuel mix coming out. It's as if the valve is just not opening. Any thoughts on what I should do next? In addition, the #3 header does not get as hot as #1/#4.
thanks.
-r
thanks.
-r
- Powerstroke_fan
Re: Cylinder 2 not firing
11 Apr 2012 18:37
Do you have fuel going to the carbs?
1977 KZ 1000 work in progress
- richrand
12 Apr 2012 08:34
yes. there's fuel in the bowls. and when i spray starting fluid into the air filter nothing happens.
