So what do you do when......
  • modprod
  • modprod's Avatar
Re: So what do you do when......
08 Jun 2006 09:33
#52930
BARNEYHYPHEN wrote:
OS73, Just a stab in the dark, and it doesn't answer the gear change problem but when you said it was steel (magnetic) and had black plastic on it...Could it be a broken off part of the cam chain tensioner?
I agree with Barney. That looks like part of a chewed up front tensioner part. They do break frequently. on these old bikes. One good thing is that it is not really a "tensioner" part to the camchain but only keeps a loose camchain from slapping aluminum when you back off the gas and the chain slack goes to the front. You have to pull the head and cylinder to replace this part...mod
  • savedrider
  • savedrider's Avatar
  • 1975 Z1-B 900
08 Jun 2006 20:31
#53093
Yeah and the part wouldn't actually be called a tensioner, but rather a cam chain guide.
Here is a picture...
Get right or get left! <*{{{><
  • OldSkool73
  • OldSkool73's Avatar Topic Author
21 Aug 2006 16:24
#71417
So ladies and gentlemen,
After two months of heartache, I scored the proverbial "huge one" and found a 1974 Z1-A 900 that a guy hadnt ridden in 15 years. His wife was going to scrap it and I got it for $200 bucks. It seems that the engine is still in great shape and it turns over freely. After tearing down my 73, I still couldnt diagnose the chunk of metal issue without cracking the cases but two of my pistons have chunks out of the skirts from hitting the crank gears....bad stuff. This past weekend I swapped the motors out and now have a 74 Z1 in what looks like to be awesome shape. The only problem I encountered now, and its a doozy, is the fact that 5 of my 8 studs for the carb holders on the back side of the jugs are broke off. Found that out tonight. Damnit. Anyone got any magical elixir that will help me get those broken studs out?? Any help would be awesome.
Thanks,
OLDSKOOL73(74)
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
21 Aug 2006 16:40
#71418
OldSkool73 wrote:
....5 of my 8 studs for the carb holders on the back side of the jugs are broke off. Found that out tonight. Damnit...
Yep, I just bought a 400 engine with one broken off in it too.
What I did was tap a dent into the center of the broken screw, get a tiny drill and drill a hole down the center, then progressively get a little bigger with each drill.
At this point, some people would try a reverse thread remover, but I just said forget it and ordered a tap and "Recoil" kit from mdmetric.com/recoil.htm ...I figured it'll happen again someday...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • btchalice
  • btchalice's Avatar
21 Aug 2006 22:20
#71495
if they stick out at all heat them with a torch and apply wax. it will usually freethem up for vice grips
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • pumps
  • pumps's Avatar
22 Aug 2006 17:17
#71670
Apply wax? Like candle wax? It will follow the threads and lube them down inside?
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
  • donthekawguy
  • donthekawguy's Avatar
22 Aug 2006 19:55
#71720
Yup works like a charm!
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • N0NB
  • N0NB's Avatar
  • Blue handles better
23 Aug 2006 10:36
#71842
I tried that some time back and got nowhere except a wax fire. In the end PB Blaster did the trick.
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
