- Thank you received: 1
1984 GPZ 1100 Engine Rebuild
- man-of-war
10 Apr 2012 22:28 #515127
by man-of-war
1984 GPZ 1100 Engine Rebuild was created by man-of-war
Hi guys, I'm planing on replacing the piston and rings on my gpz 1100 due to low compression. I did a leakdown test, the intake and exhaust are shut but the hissing comes from the oil fill hole. My lowest reading is 80psi the highest is 110psi.The engine was hot and throttle wide open. Did the same procedure but with oil in each cylinder and the reading jumped. Before I navigate into the engine I was wondering if anyone has a link to a PDF owners manual for my 84 gpz 1100.
Thanks Steve
Thanks Steve
- Thank you received: 2098
10 Apr 2012 23:33 #515148
by Patton
Replied by Patton on topic 1984 GPZ 1100 Engine Rebuild
- APE Jay
- Banned
- Thank you received: 58
11 Apr 2012 00:35 #515164
by APE Jay
Replied by APE Jay on topic 1984 GPZ 1100 Engine Rebuild
Nothing an 1170 kit won't cure :lol:
