bike wont stay running
- binnzo
10 Apr 2012 13:07 #515020
by binnzo
bike wont stay running was created by binnzo
i have a 81 kz 750 h the motor turns over when i press the start botton. when turning over it has spark and fuel and sounds fine. when i let off the start button it dies like its an electrical problem. im wondering if its the balast resistor?
any advise ?
any advise ?
- clutch
- I wish I had a tad more patience to do it better!
- Thank you received: 12
10 Apr 2012 13:37 #515024
by clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
Replied by clutch on topic bike wont stay running
Could be a loose connection inside the handlebar switch that is only making a connection while pushing the button. Power to the coils runs through there. I would inspect that as it will only take a few minutes to check.
Wish List:
Z1 (need I...
- DiamondSkyBlue1000
- Thank you received: 40
10 Apr 2012 14:50 #515046
by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic bike wont stay running
Are you saying it only runs when you have the starter button pressed?
- binnzo
12 Apr 2012 09:00 #515386
by binnzo
Replied by binnzo on topic bike wont stay running
correct
- roy-b-boy-b
- Thank you received: 103
12 Apr 2012 09:07 #515387
by roy-b-boy-b
Replied by roy-b-boy-b on topic bike wont stay running
Could you give some history on the bike and tell us if it has been sitting,if you have had the carbs apart or just bought.
- binnzo
13 Apr 2012 12:57 #515590
by binnzo
kz 750 h 1981.
stage 3 jet kit, clean carbs new carb gaskets. has sat for 8 months sinice it had last been started while it was over hauled. 4 into 1 open header with 4 pod intake. stock controls
- oldzed
14 Apr 2012 01:26 #515689
by oldzed
Replied by oldzed on topic bike wont stay running
check you have a good earth(ground) from battery to engine
Easiest way is to run a jumper cable to a clean metal part of the engine.
regards
Craig
regards
Craig
The following user(s) said Thank You: binnzo
- binnzo
25 Apr 2012 13:42 #518014
by binnzo
i will try that
- cameronkawasaki
25 Apr 2012 22:46 #518103
by cameronkawasaki
1979 KZ750B-4
Replied by cameronkawasaki on topic bike wont stay running
What happens when you try to give it a little gas?
1979 KZ750B-4
