Vance and Hines RE-Pack
- dano83-1100
- 1983 KZ1100 LTD
Is repacking the muffler something I should leave to a shop, or is it something a fairly novice wrench can handle? I don't want to get in over my head, half apart and not be able to get it back together, etc.
- DoubleDub
- Visitor
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
DoubleDub wrote: You can purchase a replacement baffle for $30 from Summit.
www.summitracing.com/parts/VAH-21869
That link is for a Hardley pipe baffle.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- DoubleDub
- Visitor
You can probably rewrap the baffle you have yourself, haven't done it myself though.
- StreetfighterKz
- Thank you received: 117
dano83-1100 wrote: however it burbles, burps, adn farts when down shifting, letting off the throttle and slowing down. Sounds really crap in my opinion.
That sounds more like carb problems than no packing in the muffler. I can't really tell but it looks like the head pipes are really blue in your avatar picture. If that's the case, your carbs are probably running lean.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
- gd4now
- Denco where did you go?
- Thank you received: 440
It does not last forever, and I do replace it every couple of years or so but it is not an expensive item. Each time I do replace it, there is a marked decrease in noise level.
As to its burbles and burps, yes sometimes adding a baffle or packing will decrease this - more back pressure. But as Streetfighter says, it can also be a carb or air/fuel mix issue. Do check it, as a too lean mix will not end well.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- DaddyJama
- Thank you received: 2
2005 636 - track bike
1982 kz440ltd - new toy;)
- munkybrain2010
- Clueless..
Wouldnt pipe bluing be cause by a lean mixture having to do with the pipes being unbaffled and less backpressure?
Keep it together man!
79 KZ650 "Geto Cycle"
- dano83-1100
- 1983 KZ1100 LTD
- Motor Head
- Thank you received: 391
