- Thank you received: 4
How do I make my clutch pull easier?
- Mercury Kid
'76 KZ900-Z1 clone
Z1 70's period longbike
- DiamondSkyBlue1000
- Thank you received: 40
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- les holt
- Thank you received: 288
Les
- Thank you received: 2098
The best place to start, imo.T_Dub wrote: ...I did take apart my clutch mechanism, cleaned and greased it....
The actuator is accessed by removing the sprocket cover.
The actuator is attached to the interior side of the sprocket cover.
- T_Dub
Yup it was a bit of a pain taking it all apart with all the tiny ball bearings, but with the amount of gunk built up in mine after 30 years I was glad I did. And like I said, APE clutch kit and its not hard to pull.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- Mercury Kid
Still getting the motor sorted but even after riding it for a couple minutes around the parking lot it was pretty tiring, and I'm not exactly a wuss haha.
Don't have the funds for the hydraulic kit, might try to piece one together from ZRX or GPZ bits.
'76 KZ900-Z1 clone
- StreetfighterKz
- Thank you received: 117
Mercury Kid wrote: Don't have the funds for the hydraulic kit, might try to piece one together from ZRX or GPZ bits.
I put a kit together for my 1000 just to be different. I used a Zx7 M/C and slave cylinder and a clutch line from a VF750...I think.
I had pics on here with a small write up but I just searched and can't find anything.
I massages the stock engine cover with an angle grinder for the slave to fit inside. It's not the prettiest but it works very well.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
- TeK9iNe
- What did you do!?!
When your oil is hot, theres no need to use the clutch to up or downshift on these bikes.
Try it -you'll thank me.
Remember, when upshifting back the throttle off quick then smooth it right back while you shift for a seemless upshift.
Downshifting is a bit more difficult. Put some pressure on the shifter peg, when your rpms come down, just bareley nudge the throttle up to a continuous cruise for that gear and shift with your foot.
You'll have it down in no time.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
