carbs synced and now?
  • bromz
  • bromz's Avatar Topic Author
  • 1981 kz1000 csr
07 Apr 2012 18:16
#514580
Got carbs synced today and now this thing is acting like its got a vaccum leak. can anyone tell me whats going on. It was running just fine before the sync and the cyliniders were only out about a pound.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: carbs synced and now?
07 Apr 2012 18:59
#514585
Were all the rubber caps by the head put back on tight ? If all that was done is sync the carbs then something didnt get put back as before
  • bromz
  • 1981 kz1000 csr
07 Apr 2012 21:27
#514613
i will check. not sure. all looked good while i was there
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
07 Apr 2012 21:58
#514617
Check for air/vacuum leaks on the carb holders and or the vacuum ports on the holders or on the carb(s).
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
