- Thank you received: 13
Can anyone link me to old builds?
- KZ802
thanks
Chris
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
- les holt
- Thank you received: 288
Les
- ramtough_63
KZ802 I used an 03 ZX6 swinger and have hundreds of pic's I didnt post if you need anything hit me up happy to help
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
- Kraz1
} Larry Cavanaugh's Build
- KZ802
anyways I'm planning on getting the same swingarm I guess since I don't have it yet I'm not really sure what it's going to take to make it fit. At this point I'm sticking with the twin shock setup. I have barely just started on my build and I so much to do I'm not going to worry about mono shock, relocating battery etc. etc. etc. So I guess I'm just wondering what you had to do to make the pivot fit in the KZ frame?
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
- ramtough_63
KZ802 wrote: I would love some help. First I have to say Wow! I just sat and read almost your whole build thread it's awesome! Books are overrated!
Thanks man appreciate you checking it out.
if it were me doing it 1st thing I would do is contact Leon (blackbanshee) send him your swingarm and let his do his bushing trick and see if he will make you an offset sprocket for the front.
while you are at it I would see if he or Les Holt would make you a reverse caliper mount. so you can relocate your caliper to the bottom of the wheel you will run into trouble with your shock mounts. and not to forget shock mounts have to be welded to the swingarm.
What size wheel and tire are you going with and also what yr wheel?
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- jonnybravo
- Banned
- Thank you received: 18
and agreed, LC rox
- ramtough_63
unless you are going with late model rearsets just trim it it is way over engineered and wont suffer from the trim.
once you get the swingarm trimmed and the bushings made to except your pivot boltput the shocks on
whith the bike on the jack lower it until you get the ride height and shock angle where you want it then have your mounts welded on.
there are a couple ways to do the brake bracket a reverse mount with or without a brake stay can be made. I am sure there are other ways, But after doing mine the reverse mount would have been the easiest for me. ( I dont have a ton of drag parts laying around to to make work.
Hope this has helped some
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- bluej58
- Thank you received: 511
78 KZ1000 A2A
- LarryC
When you're setting it all up, keep in mind the bike will sit considerably lower when you install the engine.
Larry C.
- KZ802
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
