1975 Z1900 Clutch Cable
- Z1kaw1975
05 Apr 2012 00:26 #514119
by Z1kaw1975
Z1kaw1975 BigDaddy
1975 Z1900 Clutch Cable was created by Z1kaw1975
HELLO ALL:
I have a 1975 Z1900 and clutch is hard to pull back. I was told I needed to take the cover off where the cable goes into the engine and replace this plastic part with a metal/ball bearing thing from a 1980 LTD?????
Anyone know of this fix??? I know metal is better than plastic...
Appreciate any help here!
Z1kaw1975
Z1kaw1975
Z1kaw1975 BigDaddy
- Thank you received: 2098
05 Apr 2012 01:21 - 05 Apr 2012 01:22 #514130
by Patton
The existing screw type clutch actuator is probably dry and clogged with crusty old caked grease gunge.
Would remove, disassemble, clean and and re-grease the exiting screw style clutch actuator, which may be accessed by removing the sprocket cover.
Before removing the actuator, note its angle of attachment in relation to the sprocket cover when fully retracted (not being pulled by the clutch cable). Maintain the same angle when re-installing.
Replied by Patton on topic 1975 Z1900 Clutch Cable
Z1kaw1975 wrote: ...I have a 1975 Z1900 and clutch is hard to pull back. I was told I needed to take the cover off where the cable goes into the engine and replace this plastic part with a metal/ball bearing thing from a 1980 LTD?????
Z1kaw1975
Last edit: 05 Apr 2012 01:22 by Patton.
