- Thank you received: 7
advavcer
- nobody
- moneypit
- Thank you received: 35
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- elfmagic17
- Thank you received: 24
Powerstroke_fan wrote: just losen the smaller 13mm bolt and remove it and the advancer will pull right off then i would pull it apart clean it up real good and grease it make sure it turns freely and retracts smoothly
It may slide off a little hard if it is rusted, I hade to gently stick a small flat blade screwdriver behind mine and pry it off.
Kenny Hicks
74 Honda CB550
- nobody
Attachment advancerkz004.jpg not found
Attachment advancerkz003.jpg not found
Attachment advancerkz006.jpg not found
- elfmagic17
nobody wrote: pry what ,who, this,that,me you ????????????? do have an idea about what is suppose to happen .but dont have any pictures of what it looks like apart. my book dont show much. .came with bike would be mad if i had payed money for it, need factory manual
Where the read curved line is, the little stepped portion in the top right circle. You need to get something under that and pry gently.
Kenny Hicks
74 Honda CB550
- nobody
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- nobody
- elfmagic17
Kenny Hicks
74 Honda CB550
- nobody
