reed valves-remove or connect together?
- rekit
02 Apr 2012 15:16 #513598
by rekit
1981 CBX, 1980 KZ1000, 1984 V65 Sabre, 2004 Mean Streak for now
reed valves-remove or connect together? was created by rekit
1980 KZ1000. Reeds are stuck open on the smog system. They are connected together by a rubber hose. Do I need to do anything or is that ok?
- Powerstroke_fan
- Thank you received: 83
02 Apr 2012 15:18 #513599
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic reed valves-remove or connect together?
If your running pod filters and have the stock airbox removed its ok. It stops the bike from popping while deceling.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- rekit
02 Apr 2012 15:47 #513607
by rekit
Replied by rekit on topic reed valves-remove or connect together?
Yea, K&N's. I would've thought hot exhaust gas going back and forth thru the rubber hose would melt it or worse since my reed valves don't hold. I can get air to flow both directions on both reeds.
Are we going to have to do the damn captive code on every post? This is as bad as the TSA.
- Powerstroke_fan
02 Apr 2012 20:08 #513644
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
If your worried about it you can always pull the valve cover and plug off the emmision ports.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
