- Thank you received: 25
Will a kz750 engine work on a kz650?
- ice
- Visitor
01 Apr 2012 16:02 #513402
by ice
Will a kz750 engine work on a kz650? was created by ice
Want to use a 750 engine on a 650.
Any advice?
Any advice?
- T_Dub
01 Apr 2012 16:20 #513404
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic Will a kz750 engine work on a kz650?
Should bolt right in.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
The following user(s) said Thank You: ice
- gd4now
- Denco where did you go?
- Thank you received: 440
01 Apr 2012 16:24 #513405
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Will a kz750 engine work on a kz650?
The engine should bolt in, but there may be some differences between the electrical systems that will require some work.
1977 KZ650 B1
- Godfrey
- Thank you received: 10
01 Apr 2012 20:34 #513443
by Godfrey
1981 650CSR frame
1980 KZ750E engine
Replied by Godfrey on topic Will a kz750 engine work on a kz650?
I have a 1980 750 engine in my 81 650 frame :whistle: was a bolt in :evil:
1981 650CSR frame
1980 KZ750E engine
- shockman54
02 Apr 2012 05:34 #513525
by shockman54
Replied by shockman54 on topic Will a kz750 engine work on a kz650?
@ godfrey, did you have to change any of the electrical around?
- DoubleDub
- Visitor
02 Apr 2012 06:53 #513528
by DoubleDub
Replied by DoubleDub on topic Will a kz750 engine work on a kz650?
Afaik the electrical that would need to be changed would be related to the charging system. Just swap that (regulator and rectifier) over with the kz750 engine and you should be fine.
