- Thank you received: 8
timing help
- TheFlyingFreemole
So I had to replace my head gaskets and head gasket o-ring. I also had to replace my cam end plugs and cam cover gasket. That being said, I got the gaskets replaced and everything built back up. I tried to start it up and it wouldn't fire. It doesn't pop once.
Other than having leaked some oil, the bike had been running great before.
Here's the troubleshooting I've done so far:
-Battery connected correctly. Key turned to on, kill switch to run. (Neutral and oil warning lamps will come on so electrical working)
-Spark plug wires connected in correct order. Checked plug 1 & 4, and they both had spark. Haven't tested number 2/3.
-Oil added, gas (more than a gallon) added. Gas running to carbs (through in-line filters), pulled the drain plug on the float bowl on carb 1 to make sure carbs getting gas.
-Pulled the timing cover off and lined timing mark up on the 1/4 side 'T', pulled the cam cover and checked that the marks on the exhaust cam were just a hair above the head. Rear cam had been lined up 28 links to the 28 mark. Timing on the cam chains still seems to be in place.
Everything seems like the spark isn't hitting a chamber full of fuel mixture, which seems like the timing is off. But i've gotten everything lined up according to the clymer manual... I don't know where to go from here.
1977 KZ1000 LTD B1 (needs minor fine tuning)
- TheFlyingFreemole
Attachment timingmarks.jpeg not found
it's kinda hard to see, but i put a red circle around the mark on the front/exhaust cam
Attachment frontcam1.JPG not found
Attachment rearcam.jpeg not found
- TheFlyingFreemole
Attachment frontcam.JPG not found
- bountyhunter
- Thank you received: 337
are spark plugs wet?
Is it possible you are 180 out of time?
- TheFlyingFreemole
Waiting for the RTV to set for the night before I try to give it a go... fingers crossed
- bountyhunter
- Old Man Rock
- Thank you received: 225
With crank rotation set @ 1/4 "T", from right side of bike your cam lobes should be facing each other as in these images.
Left image depicts pin count off where lobe tips should be on the money at head decking height as in the right image.
In case you need...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Old Man Rock
Does's model this have starter lock out switch i.e. such as kickstand switch...?
NOTE: This normally is for starter kill only but on a 30 year old/PO wiring who knows...
Battery voltage (+12Vdc plus) to coils...?
Spark plug test to ground head, spark...?
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Motor Head
- Thank you received: 391
Did you maybe get the wires to the primary side of the coils switched? This will make the coils fire 180 out even with the engine cam timing correct.
- Old Man Rock
Maybe this will help...
NOTE: Green off ignition goes to coil for 2/3 cylinders (right side coil)... Black goes to 1/4 cylinder (left side coil).
Also insure ideal ground to engine case!
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- bountyhunter
That's what I was asking about.Motor Head wrote: Did you maybe get the wires to the primary side of the coils switched? This will make the coils fire 180 out even with the engine cam timing correct.
- TheFlyingFreemole
how would i check to figure out if they are 180 off?
