Trans wont shift up into 2nd on stand
- Wager
31 Mar 2012 01:56 #513112
by Wager
Trans wont shift up into 2nd on stand was created by Wager
Gentlemen, I have a barn fresh GPZ1100 with 7500 miles ( wasnt abused just neglected) on my table for a carb conversion from the non working fuel injection. I just noticed that the trans will go into first and up into neutral but will not go into second. Just springs back into neutral. I am assuming this is just a broken or loose piece just inside the shift cover. Has anyone had this experience that might save me a little grief? I have just received the manual ($65) from the fellow in New Zealand so I looking forward to breaking into the side. If I have to split cases it may get pushed to the back of the shed for awhile.
Thanks Bob
Thanks Bob
- Thank you received: 1656
31 Mar 2012 03:54 - 21 Feb 2013 15:47 #513118
by martin_csr
Last edit: 21 Feb 2013 15:47 by martin_csr.
- nobody
- Thank you received: 7
31 Mar 2012 04:03 #513122
by nobody
Replied by nobody on topic Trans wont shift up into 2nd on stand
hi good luck with bike if you check in to it you will find it has a fetcher on it called positive neutral or something like that :huh: it wont shift up unless the bike is moving. mine is same way. sounds cool on one hand but maybe not dont know yet :lol: be cool man and by the way pitchers are all ways nice love um
- TomW
- Keep the blue side up.
- Thank you received: 52
31 Mar 2012 08:27 #513129
by TomW
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
Replied by TomW on topic Trans wont shift up into 2nd on stand
You could get a lot of help here to get the FI working. Possibly save some money and get a good runner worth more as completely original. Good luck. Don't feel dumb, that neutral finder gets a lot of new Kawi owners. :S
- riturbo
- Thank you received: 280
31 Mar 2012 09:10 #513132
by riturbo
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Replied by riturbo on topic Trans wont shift up into 2nd on stand
That fi is pretty easy to get going. It would be a lot easier to get that going If its all there.
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
