650 clutch
- NORT
- Thank you received: 2098
NORT wrote: Just got this 650, went through the carbs and points, got it running great. the clutch won't disengage, have adjusted the cable, just seems like the rod is bottomed out even with the side cover off. what should I be looking for?
Am thinking clutch will stay engaged with side cover off, because then there's nothing to press against the push rod which disengages the clutch.
- Thank you received: 2829
- Thank you received: 1656
- roy-b-boy-b
- Thank you received: 103
I have had them to break loose while transporting them on a trailer. I guess the back and forth motion broke them loose. Roy
martin_csr wrote: NORT: Did you do the clutch adjustment as per the manual (sometimes the manual is ambiguous, though... depending upon the bike & manual).
Ed, what direction do you have to turn the clutch release adjusting screw on your 650?
I'd guess his would be done the same as yours?
On my 81 CSR, I have to turn it counterclockwise first, then clockwise 1/4 turn.
On '77 KZ650-C1 you loosen the locknut then loosen the adjuster screw (counter-clockwise); then you turn the adjuster screw in (clockwise) until it starts to become hard to turn (this is when it begins to disengage the clutch); the you loosen it (counter-clockwise) 1/2 turn and then tighten the locknut.
I agree his is probably the same because even though his bike is a newer model the engine has been replaced with one from a 1977 bike. Ed
- KZB2 650
- Thank you received: 265
roy-b-boy-b wrote: Some time the clutch plates stick together if the bikes sits very long. You can try rocking the bike back and forth,remove the clutch plates,orcrank the bike and get it rolling and put it in gear and ride it.
Could be....my Barrnett clutch sticks together and needs to be rocked in gear to break loose after sitting a few days.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- NORT
- roy-b-boy-b
- NORT
