- Thank you received: 12
how fast does your oil darken?
- apbling
1982 550 LTD. Few years back I holed my #2 piston. After alot of screwing around, I FINALLY have it runnining right again. One think I notice though is when I dropped my oil the other day and replaced it, it seemed to get darker rather quickly.
Now, the oil that was in it was about 2 years old, and I have some leftover from the wife's scooter and my shadow, but no filter. The filter only had maybe 15 miles on it, so I just dropped the oil and filter, but put the filter back in. I plan on replacing it very soon, but the bike isn't even licensed yet, so I don't go anywhere with it. I just wanted to get that old oil out of there...
Anyway, now I'm worried that I might have some blow by from the cylinder I blew. It has new rings, valve seats and a hone. It's compression is about 130, whereas the others are 150. I was *hoping* that once I get some miles on it that it would increase a bit as the valves and rings wear in....
How could you tell if I do in fact have blow by? A leakdown test would show that, but wouldn't it show the same thing if the valves weren't perfectly tight too?
- DiamondSkyBlue1000
- Thank you received: 40
You should have replaced the filter as well. Used motor oil becomes acidic over time and will react to the rubber and metals in your engine, especially aluminum. The filter will hold oil in it and when you fired the engine up, that oil just got recirculated with the new stuff.
A leakdown will tell you whether you have leaky valves or ring blowby by listening to where the air is leaking; intake, exhaust or case.
- apbling
- bountyhunter
- Thank you received: 337
You may have sludge buildup in the engine because of that. Buy some gallons of decent oil at Walmart and change the oil frequently (whenever it turns black) and maybe it will take some of the crud out.apbling wrote: Now, the oil that was in it was about 2 years old,
- apbling
The oil that was in there was actually 10-30 regular motor oil. That's all we had at the time, and figured it was good enough for just getting it started. Maybe it's all in my head, but I SWEAR my clutch feels better now that it has motorcycle oil in it and not regular motor oil. I used to have issues with the plates sticking together, so after it sat a little bit and I started it and put it in gear, it would snub because the clutch was clinging a little bit. Usually once it did this it was fine to go.
- bountyhunter
It probably says "energy conserving" on the top of the 10-30 car oil and that means it has moly in it which can ruin a bike's clutch. Never use an "energy conserving" oil. Most any 10-40 will not have the moly in it but read the top to be sure.apbling wrote:
The oil that was in there was actually 10-30 regular motor oil. That's all we had at the time, and figured it was good enough for just getting it started.///Maybe it's all in my head, but I SWEAR my clutch feels better now that it has motorcycle oil in it and not regular motor oil.
That's very good oil, a lot of people run it. But you can use castrol GTX, valvoline, or just about any decent 10-40 as long as it is not energy conserving. If it is blacking up the oil quickly, just change more frequently for a while.apbling wrote: Now, alot of people have been talking about the diesel rotella T. Is that what you are referring to?
Make sure the oil has enough ZDDP in it (at least 1000 ppm) or your cams will wear too much. Many bike oils have enough, some don't, but any oil that says "SN" on it basically has no ZDDP in it. I think "SM" has a little but not enough. If you have oil which doesn't have ZDDP in it, you can get additives to put in. A can of STP oil treatment will raise ZDDP enough but also raises viscosity about 4 points.
- bountyhunter
- xmoney
1992 Harley Davidson FXDC Full Custom
1982 KZ 750 N1 Cafe project
1970 BSA Thunderbolt OIF W/ Lightning twin carb Head Bobber/ Cafe Stayle (Project )
- apbling
Around here I can get motorcycle oil for about the same price as any of the other oils. Since the shop is near my work I have just been using the Honda GN4 or whatever they call it.
