Wrist pin circlip fell in the hole
- Sketchproject
27 Mar 2012 18:17 #512361
by Sketchproject
1975 KZ400 D
1980 KZ550 LTD
(1997 H-D Sportster 883)
Wrist pin circlip fell in the hole was created by Sketchproject
When I was installing the pistons ('75 kz400), one wristpin circlip fell into the crankcase (yes, the hole was covered with a rag & it still fell in). I heard it hit the crankcase plate near the bottom of the engine. After trying to retrieve it for 45 minutes (magnets, flashlight, long needle-nose pliers, vacuum), I'm pretty sure it fell below that plate. I really don't want to separate the halves again for a stupid like freakin' circlip. What's the chance that it will grenade the engine? Might it just disintigrate instead? Any ideas what to do? I'm really frustrated right now.
1975 KZ400 D
1980 KZ550 LTD
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
28 Mar 2012 04:33 #512453
by SPARKY47
1980 KZ500 B2
Replied by SPARKY47 on topic Wrist pin circlip fell in the hole
You can't leave it in there.Get it out,persevere with the magnet.
If you don't,you can bet your life(literally) that it'll self destruct at the most awkward moment(at speed,in traffic).
Get it out.
Get it out.
1980 KZ500 B2
- Thank you received: 2829
28 Mar 2012 09:54 #512481
by 650ed
Replied by 650ed on topic Wrist pin circlip fell in the hole
I looked it up. According to Mr. Murphy's Lawbook the odds are 100% it will not hurt your engine until you least expect it. Then it will.
- roy-b-boy-b
- Thank you received: 103
28 Mar 2012 10:06 #512484
by roy-b-boy-b
Replied by roy-b-boy-b on topic Wrist pin circlip fell in the hole
I have had this happen and tried everything and failed to get it out. A friend suggested washing the cases with carb cleaned and sure enough it was stuck to the side of the case.
Can you try this and maybe the clip will move to where you can get to it? Roy
- Motor Head
- Thank you received: 391
28 Mar 2012 10:06 #512485
by Motor Head
Replied by Motor Head on topic Wrist pin circlip fell in the hole
Pull the oil filter out first, and see if you can retrieve it there. If not then pull the oil pan/ sump off, then you can get the clip and clean the sump.
- Sketchproject
28 Mar 2012 13:28 - 28 Mar 2012 13:28 #512533
by Sketchproject
1975 KZ400 D
1980 KZ550 LTD
Replied by Sketchproject on topic Wrist pin circlip fell in the hole
Got a good night's sleep, took off the primary cover, stuck my telescopic magnet in the hole and out came the part! Week just got 100% better! Now to never do that again... Thanks for all the help guys!
1975 KZ400 D
1980 KZ550 LTD
Last edit: 28 Mar 2012 13:28 by Sketchproject.
28 Mar 2012 14:56 #512550
by 650ed
I know it felt REALLY good to see that clip come out on the magnet! Ed
