how high will it spin
- chancelton
29 Mar 2012 10:55 #512728
by chancelton
Replied by chancelton on topic how high will it spin
yea i guess its something im gonna have to just play with till i get it dialed in.
i just dont wanna break it in the process
- LarryC
29 Mar 2012 11:08 - 29 Mar 2012 11:13 #512731
by LarryC
Does it have Shim on Top or Shim on Bottom Buckets?
If you're going to twist the thing to death, Shim on Bottom is what you want. Remember, a free wheeling motor that's past it's peak HP RPM is only consuming time without gaining anything.
Try launching about 6500 and set your limiter to 9000 to start with, then adjust from there. If the motor is producing respectable torque, it will leave just fine. The rest is in the gearing and how well you can launch it
How many gears are you actually using anyway?
Larry C.
Replied by LarryC on topic how high will it spin
chancelton wrote: yea i guess its something im gonna have to just play with till i get it dialed in.
Larry C.
Last edit: 29 Mar 2012 11:13 by LarryC.
- chancelton
04 Apr 2012 11:14 #513992
by chancelton
it has a mystery 2 speed transmission. i havent looked in to the transmission or slipper clutch at all yet. i have no idea what the heck i have
except for another question,
what is the spec for valve clearance, shim on top for the old kz
- chancelton
04 Apr 2012 15:13 #514042
by chancelton
just seems like .004 isnt enough, i know in automotive applications a valve stem will grow that much with heat on the exhaust side
- LarryC
04 Apr 2012 16:24 #514054
by LarryC
Larry C.
If you want, you can go to .006" lash. No problem at all.
Larry C.
