how high will it spin
- chancelton
cam specs as follows
lift .410
duration at .04 250
lobe centers 108
this is a drag race only machine and im curious what rpm to launch at and shift at
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- chancelton
- chancelton
- testarossa
chancelton wrote: yea and i have no idea what, if anything, has been done to the bottom end. Allegedly, the guy that built the bike launched at like 8k rpm but i am not sure. i was hoping with the cam specs some of you smart guys could maybe tell me at what rpm my power curve will decline
Ask LarryC, but he's going to need more information that what you provided. What carbs, what size valves, any port work, compression ratio, etc?
2004 ZX-10R
Angola, IN
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
- Thank you received: 2829
This really is the key because the power will normally begin to taper off before your engine over revs. Determining this can best be done on a dyno. Ed
- LarryC
Depending on the head & carbs, it could peak anywhere from 8500 to 9500.
I watched a guy with a 1327 drag bike pound the living daylights out of the motor and it didn't go quicker. Had an 88CFM C&W KZ head with 36/31 valves, 38mm Trons and an old set of worn out 8X Andrews Cams.
He could't break a 6.0 1/8th mile with it. His buddy had an 1135 J motor bike running 6.3's with something like 14/50 gearing on it. He kept telling the KZ guy the bike needed lower gearing. KZ guy kept gearing it down and it slowed down to 6.1 - 6.3. He was launching the thing at 9500 with the limiter set at 10,000..... :whistle: I had nothing to do with that bike other than to observe and console the poor guy who was trying to get the owner to listen to him......
Larry C.
- jeffasaki
- Thank you received: 44
WHY WHY WHY
I wonder how that broke
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- chancelton
the bike is actually a custom frame laydown 3 wheeler with paddle tire for sand drag racing and i dont wanna but tires just for a dyno run. the paddles will come off the tires if i get on it on anything hard packed, and at 500 each its not worth it.
i certainly appreciate all the responses guys and I think I gonna set the limiter at 10 and hope for the best. try to leave at around 8k and hope i get enough traction to actually use low gear.
I just got this thing last year and have only made 7 runs on it and it ran terribly. story behind this bike is the guy that built it made it go fast and then sold it and there has been 5 owners since then and it hasnt gone fast for any of them. I wanna be the guy that fixed it. so over the winter i checked compression and it was awfully low so i pulled the head and found that the clearances were way too tight for the valves, had 4 broken valve springs, the headgasket was obviously leaking and the cams needed to be re degreed. so i am trying to get this thing as close to perfect as i can to go shock everyone april 7th.
anyway thanks again for all the advice guys, its much appreciated.
oh, and some eye candy
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
I'm saying it will nose over around 9-9,500.
Flat slides would wake it up.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
