cam and camchain timing
  • nitrochristian
  • nitrochristian's Avatar Topic Author
25 Mar 2012 23:12
#512004
Ok guys i have a 1978 kz650, bore kit to 710cc and a gpz750 intake cam stock carbs 25hp shot nitrous extended swing arm 05 ninja frontend, and many fabricated parts. i ran into a snag i think? i set the crank at 1-4 tdc and installed the exhaust cam with the t mark facing front lined up with the top of head valve cover gasket surface per the manual then the intake cam with the t mark facing rear at gasket surface. i then counted chain pins from the first pin after t on exhaust to 36th pin at intake cam t mark. heres the issue after rolling engine over several times with chain guide roller installed and cam chain tensioner installed, when i stop a 1-4 tdc the exhaust cam t mark lines up good with gasket surface but intake t mark is about 1/16 to 1/8 below gasket surface to the rear. what do you guys think. sorry so long winded but tried to cover all :blink:
78 KZ650
96 Ford Bronco
  • zed1015
  • zed1015's Avatar
Re: cam and camchain timing
26 Mar 2012 06:57
#512045
That's pretty much normal.
They hardly ever line up perfectly with the head due to a stack up of small factory intolerances created in mass production and cam chain stretch etc.
As long as you've got the pin count correct back from the exhaust cam and the timing is not a full tooth out you will be ok.
I would slot the sprockets and degree the cams in to get the best out of your cams etc.
Set them at the std factory lobe centers to start, You will be suprised how much crisper running this can make the engine.
  • Old Man Rock
  • Old Man Rock's Avatar
26 Mar 2012 08:58
#512048
"i then counted chain pins from the first pin after t on exhaust to 36th pin at intake cam t mark."
Possibly I'm not reading this correctly...
* Install exhaust cam with alignment mark parallel to head decking.
* Then count 1 pin up, this is your number 1 pin count....
Just in case different then yours...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
