Chewing through starter brushes
  • n8miller
  • n8miller's Avatar Topic Author
  • '82 KZ 750 LTD H3
25 Mar 2012 22:52
#511993
My 82 kz 750 has chewed through 3 starter rebuild kit brush sets in 3 years. I finally put an expensive oem set on and I haven't opened her up yet but I think shes chewed through these already. I only crank her 15-30 times a year so I know it's not over use. Any suggestions?
  • baldy110
  • baldy110's Avatar
Re: Chewing through starter brushes
25 Mar 2012 23:05
#512001
I would say your bushings are worn out.
  • zed1015
  • zed1015's Avatar
26 Mar 2012 07:25
#512046
Only 15-30 times cranking to wear out the brushes seems extremely excessive even if the motor bearings were shot.
Sounds more like inferior grade carbon brushes but if the OEM ones go the same way then i'd look at the surface they run on.
If the commutator is badly worn,uneven and dirty this will cause the excessive wear .
Also a bad contact area will cause arcing which will eat brushes in the same action as an arc welder transfers material from the filler rod to the workpiece.
I would recommend setting the armature in a lathe and trueing up the commutator and then cut back the mica so that the new brushes have a clean, unworn even surface to run on.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
26 Mar 2012 19:21 - 26 Mar 2012 19:21
#512150
Maybe just price another starter?
1977 KZ 1000 work in progress
Last edit: 26 Mar 2012 19:21 by Powerstroke_fan.
