- Thank you received: 133
Stutter/stumble at constant RPM
- Topper
It sort of feels like it's mis-firing or something.
I could use some advice about where to start to look to track this down. I'm thinking of starting with the timing advancer and making sure it's clean and not sticking.
Does that sound like it could cause this?
Thanks!
-Topper
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
- Topper
1979 KZ750 Twin
- baldy110
- Thank you received: 512
If not then I would start with a complete tune-up and go from there.
- Topper
It's always done this, but it's one of those things that is difficult to reproduce on demand.
1979 KZ750 Twin
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
- Topper
Am I right to suspect the timing advancer or is that off base?
1979 KZ750 Twin
- andy9802gt
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- bountyhunter
- Thank you received: 337
Sounds more like a carb problem. Check for vacuum leaks at the intake manifolds. Check for slits in the carb diaphragms. Check fuel levels in the bowls.Topper wrote: Sometimes my '79 KZ750 stutters or stumbles when I'm cruising at a constant rpm. It seems to happen between 3500-4000 rpm. If I give it a little gas it levels out.
What jets are you running?
If you have the stock BS-38 carbs, increase the pilot jets to #50 and they will run better. If you have the 40's that came in the California models, they will NEVER run right.
Are you running pods and/or low restriction exhaust?
The timing advancer can cause problems, always good to check that.
- les holt
- Thank you received: 288
Les
- Topper
bountyhunter wrote: If you have the stock BS-38 carbs, increase the pilot jets to #50 and they will run better. If you have the 40's that came in the California models, they will NEVER run right.
Believe it or not it had 35s in the carbs when I bought it. Popped like hell but ran. I put 40s in when I cleaned the carbs. Still pops a little on one side especially on decel. I've been thinking about upping to 45s ever since.
FWIW I'm running stock airbox, aftermarket exhaust with mufflers.
I think I'll have some time this weekend to check out the timing advancer.
1979 KZ750 Twin
- bountyhunter
45 pilots run "OK" but you can't get the decel popping to stop. It runs better with 50's. No popping, better throttle response.Topper wrote:
- toadson
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
