Help! Engine cut out on highway, soft seize?
- vandenbusschebr
25 Mar 2012 03:36 #511817
by vandenbusschebr
77 kz750 twin.
pods, open pipes, rat smoker
2012 fz8
Help! Engine cut out on highway, soft seize? was created by vandenbusschebr
Apologies if this is posted somewhere else, but all I keep finding are posts about brake calipers seizing...
Was coming off the freeway today and the engine cut out. Happened as I pulled in the clutch to downshift. Pulled over and couldn't restart. pulled the plugs and couldn't even kick start. the pistons would barely move (w.o the plugs in) BUT then after walking to the gas station and back i dropped some oil in the cylendars and was able to lube them up enough to get them to move freely again. put the plugs in and was able to kick start it. Rode home at low speeds and it didn't happen again.
Bike was not low on oil and not leaking anywhere.
Anyone have an idea of what this sounds like? what may have caused it? what can i do to prevent it?
thanks,
Brett
thanks,
Brett
77 kz750 twin.
2012 fz8
- Thank you received: 2829
25 Mar 2012 11:45 #511853
by 650ed
Replied by 650ed on topic Help! Engine cut out on highway, soft seize?
When is the last time you changed the oil? What oil did you use? Are you running pods without rejetting the carbs? What model motorcycle is it?
- Mike Mecredy
- Thank you received: 1
25 Mar 2012 20:21 #511966
by Mike Mecredy
1997 KZ1000 police
Replied by Mike Mecredy on topic Help! Engine cut out on highway, soft seize?
I never had that happen with a 4 stroke but I over heated a 2 stroke as a kid and when the engine cooled off the, the parts "shrunk" and I got it started but would'nt stay running. We rebuilt the top end and fixed it. But it was totally siezed up at one point before it cooled off.
What type oil did you use in it?
1997 KZ1000 police
- Thank you received: 2098
25 Mar 2012 22:41 #511988
by Patton
Replied by Patton on topic Help! Engine cut out on highway, soft seize?
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future. And may be changed whenever and as often as desired.
Attachment addsig.jpg not found
- steell
26 Mar 2012 15:50 #512124
by steell
:whistle:
Oh my.
Replied by steell on topic Help! Engine cut out on highway, soft seize?
carloslee wrote: Why don't you give your bike for servicing. They will change the oil and fix all problems if any. And only they can give the reason why your bike got stuck.
:whistle:
Oh my.
- Powerstroke_fan
- Thank you received: 83
26 Mar 2012 19:18 #512149
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Help! Engine cut out on highway, soft seize?
dang newbies lol
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- vandenbusschebr
30 Mar 2012 21:37 #513082
by vandenbusschebr
77 kz750 twin.
2012 fz8
Replied by vandenbusschebr on topic Help! Engine cut out on highway, soft seize?
have it serviced? where is the fun in that?
Anyway to those that enjoy wrenching...
77 kz750 twin. Stock (no engine mods) no pods
exhaust pipe is a bit pitted.
it was low on oil, about half quart.
Talked to a shop, they said if oil pump goes then compression will be down... anyone know if this is true?
checked compression today 155 in the left and 160 in the right (warmed up engine)
Bike seems to start and run fine (when I drive it a few miles)
I'm just nervous to take it out again and end up stranded!
77 kz750 twin.
2012 fz8
- vandenbusschebr
30 Mar 2012 21:41 - 30 Mar 2012 21:42 #513084
by vandenbusschebr
77 kz750 twin.
2012 fz8
Great advice patton! These tips are great to us new riders!
77 kz750 twin.
2012 fz8
Last edit: 30 Mar 2012 21:42 by vandenbusschebr.
