Revival was short lived!
- LukeMacPU
23 Mar 2012 22:11 - 23 Mar 2012 22:14
I've been working for a while now on getting my Z1-B back on the road. Things seemed to be going well. I had changed oil, filters, checked valve clearances and adjusted, replaced tach drive, wheel bearings, tires, and lots of other odds & ends.
It would kick-start easily in the garage even before I adjusted the valves, so I was pretty excited to get the new tires on and take it for a quick spin. I basically ran to the gas station and back, total trip roughly 10 miles. I say roughly, because the speedo/odo stopped working about 1.5 miles from home. Not a big deal, I can fix that.
What worries me is that when I got home, the bike was feeling very sluggish. When I left, it roared out of the driveway and down the road. When I got back, it would barely take off from a stop on flat pavement, and I couldn't get up the substantial hill to my house. Had to push/pull it home.
Engine runs, but when put under load it, acts like its getting bogged down. Must have lots of throttle to rev up even in neutral. I haven't begun to dig into why it stalled out. Really didn't have time today for working on it, had just planned the short test ride primarily to fill up with fresh fuel. Looks like the test was a failure.
Any suggestions on where to begin? Bike was running great on the center-stand before I left and seemed decent on the road for the first half of the trip. It felt a little hesitant leaving the gas station, but I didn't think much about it. I've never ridden the thing before and the clutch was still a little stiff/grabby. By the time I covered the 5 miles home, it was obvious things weren't going well, but no idea why. Engine seemed really hot when it died on the hill.
'75 Z1B - work in progress
Last edit: 23 Mar 2012 22:14 by LukeMacPU.
- DiamondSkyBlue1000
- LukeMacPU
Re: Revival was short lived!
23 Mar 2012 22:40DiamondSkyBlue1000 wrote: Sure it's not brakes or bearings?
I'm pretty sure those are good. The bike rolls no problem. I can easily push it around, the engine just can't seem to. Brakes/bearings were in the odd & ends category above.
23 Mar 2012 23:46
Was there any rust or crud in the fuel tank that could have made its way into the carbs as the bike ran? Ed
24 Mar 2012 00:04
Following ed's lead; petcock on? fuel flowing to carbs okay? Sounds like it's running out of gas. That would cause it to bog like that and also run hot. Check that out and if it's all good, check your advancer on the ignition (long shot). Make sure your charging system is working, if you are running off of the battery, you will get symptoms like those you described as the battery runs down.
We're shotgunning here but it's a start.
- testarossa
24 Mar 2012 00:20 - 24 Mar 2012 00:20
You might do well to have a look a your ignition advance mechanism. Could be as simple as counterweights that need to be freed up and lubed.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
Last edit: 24 Mar 2012 00:20 by testarossa.
- elfmagic17
24 Mar 2012 00:44650ed wrote: Was there any rust or crud in the fuel tank that could have made its way into the carbs as the bike ran? Ed
+1 Have you pulled you fuel screen? My CB360 had a very plugged one and it used to go 22 miles back and forth to work fine then all of a sudden it started to bog and slow down, It would go half way and then just bog and die. I would stop let it sit and then it would fill the bowls up and go another couple miles and do the same thing. Finally pulled the fuel hoses loose right away when it happened and no fuel came out of the petcock. Removed the bowl and looked at the screen and it was plugged with rust. I Cleaned it with Iron-out and a old tooth brush in a old paint cap with a little water. Works perfect now. Tank didnt even look that rusted. Just my own experience, but it may help though.
Kenny Hicks
74 Honda CB550
74 Honda CB550
- LukeMacPU
24 Mar 2012 08:14 - 24 Mar 2012 08:16
Thanks for the tips guys. There was light rust/crud in the tank when I got it. I've removed the pet-cock, cleaned it, rinsed the tank with fuel several times, and re-installed. More crud preventing fuel flow is very possible, I'll look into that.
It could also be the timing, I didn't check that the advancer was working when I replaced the point/condensers. I'll look into this too if the fuel is flowing well.
If the timing was off (advancer was stuck) would it cackle more on decelleration? Sounded a little different when I fired it up to head home from the station.
Last edit: 24 Mar 2012 08:16 by LukeMacPU.
- mark1122
- Keep twisting it
24 Mar 2012 08:30
would it cackle more on decelleration? that sounds like a lean condition. could be rust.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- jonnybravo
- Banned
- KZQ
- Administrator
24 Mar 2012 10:09jonnybravo wrote: is ur tank/gas cap vented ???
JB's on it. Next time it happens pop open the gas cap.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Gman
24 Mar 2012 13:25
How's your eng oil level? The eng shouldn't be that hot from a short run.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
2002 Gold Wing
1974 Z1 900 project
