head swap, will it work?
  • hx35w
  • hx35w's Avatar Topic Author
21 Mar 2012 22:26
#511135
Will a 1978 kz1000 A2 head work on a 74 Z1A top end?
  • DFIGPZ
  • DFIGPZ's Avatar
Re: head swap, will it work?
21 Mar 2012 23:17
#511146
yes but the kz1000 has 8mm ex studs where the 900 head has 6mm ex studs.
1984 750 Turbo
  • wireman
  • wireman's Avatar
22 Mar 2012 02:56
#511188
Dont forget to use your z1 cam sprockets if using the newer cams also B)
  • hx35w
22 Mar 2012 18:10
#511304
So, the 1000 cams are different?
  • zed1015
  • zed1015's Avatar
22 Mar 2012 19:11
#511315
No.
All 900 and 1000 three bolt cams are basically the same.
Just don't get MK2/ST (Square cam cover) cam sprockets mixed up with earlier ones as they have 2 more teeth and will only work with the mk2 crank.
Mk2 cams do however have fractionally higher lift.
  • hx35w
22 Mar 2012 21:25
#511332
So the cams and cam sprockets are the same in the 78 1000a2 and the Z1s
  • wireman
  • wireman's Avatar
23 Mar 2012 23:46
#511570
zed1015 wrote: No.
Yeah I was having a senior/medicated moment thinking of mkII cam sprockets :sick: :laugh:
  • hx35w
24 Mar 2012 10:11
#511625
Thanks for all the replies guy's
  • zed1015
  • zed1015's Avatar
25 Mar 2012 10:59
#511838
hx35w wrote: So the cams and cam sprockets are the same in the 78 1000a2 and the Z1s
Yes! just they are 30 tooth. Later MK2 are 32 tooth.
As long as they are 3 bolt fixing just use your original cam sprockets and you can't go wrong.
