- Thank you received: 1
Proper head and cams
- Yorke2112
I have a torn apart kz750 motor w/parts, and an 82 GPz 750 head minus cams. Right now, the bike runs pretty damn good, but I have been wondering if I should build the 750 motor. Put the 750/810 big bore cylinders and GPZ heads with bigger cams.
Do you think there would be a big performance increase? Enough to warrant building the 750 and tearing the 650 apart? What are the biggest cams you recommend for street use?
- LarryC
Yorke2112 wrote: I have a kz650 that has 750 cylinders and a big bore 810 kit installed. I am currently using the 650 head with 750 cams, and 28mm mikuni's.
The 750 head flows 10CFM more @10" of water than the 650. With an 810 piston kit, I'd go that route.
Larry C.
- zukdave
- Thank you received: 229
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
