- Thank you received: 1
why no compression
- TorreyJ
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- TorreyJ
- Thank you received: 2829
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Thank you received: 1656
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- mark1122
- Keep twisting it
- Thank you received: 109
Powerstroke_fan wrote: Just looked it up go to T on 1&4 make sure it lines up with your mark,make sure the arrow on the exhaust cam sprocket lines up with the front of the head and it is parralel with the top the head. then make sure the intake cam sprocket arrow faces the rear parralel with top head the same as the front just facing the rear instead foward.then look at the exhaust cam and see the pin on the cam chain that is excatly even. that is 0 start with the next pin up as 1 then count 36 pins and it should line out with the arrow on the intake cam
X2
did u check the valve clearance? if u have no clearance u may have no compresion.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- bountyhunter
- Thank you received: 337
I don't think it matters as long as you are at TDC. At least it doesn't on mine.TorreyJ wrote: no matter how hard I try, I cannot get this thing timed right... I have a compression tester but no matter how I adjust the chain I can't get compression...maybe I should just try to start it but I can't see why I wouldn't have compression. 81 650 CSR. Can someone explain the T|F|1-4 marks to me or give me some Idea what I'm doing wrong? how do you know which revolution to time the crank on? I'm uber frustrated...
- kaw-a-holic
- Thank you received: 249
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
