Gearbox/Transmission
  • limp
  • limp's Avatar Topic Author
19 Mar 2012 12:38
#510631
Hi all
Can anyone help me out please, i asked sometime ago about changing a shaft drive Z1000 engine over to a chain drive which my bro is building (thanks for the info last time) what me bro is after now is a picture of the gear selector mechanism behind the sprocket cover wich would show all the moving parts springs, clips, and anything else that may be there. if i am right would a picture or diagram of a mk2 or an A model be ok
kind regards
Limp
Hi
I'm Graham (limp)I live in the Leicestershire area of England have just finished this Z1000,it is an H1 engine fitted with carbs which are 29mm mikuni's,LTD frame,Yamaha FJ1100 front end it handles very well and goes like a rocket :)
  • TexasKZ
  • TexasKZ's Avatar
Re: Gearbox/Transmission
19 Mar 2012 12:47
#510632
Have you tried the search function on this forum? I remember seeing a discussion of this topic a while back.
You can find parts diagrams at Kawasaki's website - www.kawasaki.com/Products/Motorcycles.aspx
Hover over "Owner Info"
From the menu, choose "parts diagrams"
Next, press "Continue" next to "Motorcycle"
On the next screen, choose the year you are interested in, then press "Continue"
From this page, choose the model you are interested in, ans WHALAH! Parts.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
19 Mar 2012 17:17
#510671
have u looked in a shop manual? how about a parts diagram on line ?
heres 1 .
www.powersportsplus.com/parts/search/Kaw...A4+KZ1000/parts.html
Attachment H-12.png not found
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • limp
19 Mar 2012 17:45
#510678
Thanks very much for this info i shall take a look around this site as you suggested
Kind regards
Limp
Hi
  • limp
19 Mar 2012 18:01
#510679
Thanks for the diagram Mark ive lost the manuals that i had but will try the link
Kind regards
Limp
Hi
  • etbike3135
  • etbike3135's Avatar
19 Mar 2012 19:04
#510695
Not a hard change over just make sure you have EVERYTHING from a chain drive motor. Shift drum, springs clips. You can use earlier stuff also in you cases like KZ/Z1, it will work as long as you take everything from one motor for the next.
1973 Kawasaki Z1
18 years in dragbikes
The following user(s) said Thank You: limp
