KZ550 project ..help
- Wizard of Smiles
- New to classic motorcycles
1980 kz550a
Not running.
- Flyndrive
- Thank you received: 4
1980 KZ 550A1
1985 GPZ 900R
- Wizard of Smiles
I think we took a little bit.
All help welcome. I will tell you what we did in as much detail as I can.
1980 kz550a
Not running.
- Beav
- Thank you received: 1
- loudhvx
- Thank you received: 1616
Check my signature for a lot of 550 info including the factory service manuals.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Wizard of Smiles
1980 kz550a
Not running.
- Wizard of Smiles
1980 kz550a
Not running.
- Wizard of Smiles
1980 kz550a
Not running.
- 1slowkayzee
1975 kz400
Harrisonburg, virginia
- apbling
- Thank you received: 12
- twin_rotor
apbling wrote: At the risk of sounding like a wise ass, have you pulled the clutch in? On my 82 550 LTD you have to (well, not mine anymore ) pull the clutch in to start it. It's a safety device.
+1
My 550 didn't have a clutch safety switch(or it was missing/bypassed). My 1100 does. I catch myself selecting neutral and forgetting to pull the clutch in all the time..
If it is locked up, the marvel will only free the rings. You'll still have to address the corrosion build up in the cylnders. If you don't, you can easily break a ring if the ridge is large.
-Ben-
1983 KZ1100A3
- Wizard of Smiles
1980 kz550a
Not running.
