Inj. holes-best way to plug em w/o removing head
18 Mar 2012 12:36 #510423 by rekit
My 80 Classic has some rubber well plugs, and some are bad. I saw drill and tap, but afraid some shavings would get in motor. Block off plates?
1981 CBX, 1980 KZ1000, 1984 V65 Sabre, 2004 Mean Streak for now
18 Mar 2012 13:52 #510436 by roy-b-boy-b
Replied by roy-b-boy-b on topic Inj. holes-best way to plug em w/o removing head
I saw a Classic week before last that had JB weld in the for over 20 years. Just be sure to clean the holes out good. roy
  • BlackZ1R
  • Kawasaki in my blood
17 May 2012 09:16 - 17 May 2012 09:17 #522876 by BlackZ1R
Nickle 38 special cases with JB weld.
If you are worried about tapping chips getting into the engine, rotate the crank until the exhaust valve is closed on each port you are tapping Once you have it tapped, just blow through the port with compressed air. Any chips should be blown out the exhaust ports.
Pull your exhaust pipes off and look into the ports to make sure you got em out. It's going to go out the exhaust anyway, so it shouldn't cause any problems internally.
One good way to catch most of the chips is to use tapping wax on your tap. In my experience it catches most of the chips made from tapping.
Hope this helps.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
Last edit: 17 May 2012 09:17 by BlackZ1R.
17 May 2012 11:45 #522904 by damarble
That sounds like it would work but I'd take off the header FIRST. You don't want chips sitting in your exhaust. If you're running WOT and suddenly snap the throttle shut, it's possible to suck the debris back into your motor. May not happen, but not worth the risk. I've seen a few cars suck the disintegrated catalytic converters into the motor.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
  • BlackZ1R
17 May 2012 12:30 #522909 by BlackZ1R
Yeah, that's the way I intended to state that post, I just never get stuff written out like I'm thinking it. :silly:
Before my morning coffee :cheer:
Kawasaki
17 May 2012 12:40 #522913 by 531blackbanshee
Replied by 531blackbanshee on topic Inj. holes-best way to plug em w/o removing head
i thought he was asking about plugging the fuel injector holes :blink: .
18 May 2012 03:18 #523059 by rekit
Yes, the fuel injector holes on a "G" model. I ended up keeping the well plugs. I put some sealant around em and made some block-off plates from small aluminum angle stock, using the two screws to mount them. This keeps the plugs from popping out.
  • BlackZ1R
18 May 2012 10:28 #523082 by BlackZ1R
531blackbanshee wrote: i thought he was asking about plugging the fuel injector holes :blink: .
:P what can I say leon, the noobs strike again. I was thinking smog ports when he said block off plates. :blush:
Kawasaki
18 May 2012 10:40 #523087 by 531blackbanshee
no sweat kev. :)
it's like possum hunting,
the first thing you have to do is get out in the woods :lol: .
then you can start honing in on the objective. :P
