- Thank you received: 1
1978 KZ650 - can't drain all the oil!?
- TheHolk
Restored an old (rotten) low mileage KZ650 - after pouring lots of money in it (ignition, coils, new wheels, seat, tires, chain, sprocket, master cyclinder, new pipes etc) it finally runs great.
I've made two oil changes and according to the manual the engine holds 3.6 liter of oil, so I was expecting that I would drain and replace at least around 3.4 liter. Oil level was right in the middle. Although I drained it on center stand and replaced the oil filter and let it sit for a while, I was just able to pour in 2.5 liters and the oil level was where it should be (even after starting and test riding it). Oil goes black very fast as well, another indicator that I haven't drained everything.
What do I do wrong?
Thanks!
Holk
1978 KZ650
2009 Ducati Hypermotard
1981 Vespa P200E
- Old Man Rock
- Thank you received: 225
Pull the oil filter out and inspect for crap, metal shavings, RTV pieces etc... Possibly it's clogged and holding oil ~ 2/3 quart.
I don't have a center stand so how I do mine is using a rear wheel/swing arm lift, raise the rear of the bike. This places the rear higher then the front so naturally, oil should flow downwards towards the oil drain plug...
I'd also want to insure oil is reaching the camshafts... henceforth oil is pumping/flowing.
Oil pressure to specifications?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- Thank you received: 2098
- TheHolk
Will remove the oil pan next time and post pics!
1978 KZ650
1981 Vespa P200E
- Thank you received: 2829
- TheHolk
Thanks for the help!
1978 KZ650
1981 Vespa P200E
- bountyhunter
- Thank you received: 337
More likely:TheHolk wrote: Hi,
1) blowby the rings
2) did you clean the bottom end when you worked on it? Drop the pan and clean the inside out.
If the oil is "blacking up" fast, good thing is to get some cheap gallon jugs of decent oil at WallyLand and change frequently until the sludge gets cleared out.
- bountyhunter
I used to do that.... when I was much younger. make sure when you add the new oil, you "kick it up" well enough to fill the filter and pump. Kicking the engine dry empties them out.TheHolk wrote: Sooo, oil change was due and I poured some Seafoam into the crankcase yesterday. Was riding the bike to work today (50 miles) and changed the oil tonight. Got something like 3.3 liter out of it - much better. Used the kickstart a couple of times to make sure everything gets out.
