How can I lower the front of my 85 GPz? Should I?
- H-60MGuy
- 1985 GPz 750 Streetfighter
17 Mar 2012 22:44 - 17 Mar 2012 22:56 #510294
by H-60MGuy
"See, what had happened was.........."
How can I lower the front of my 85 GPz? Should I? was created by H-60MGuy
Now that I have 70 miles on my Engine build, I am getting close to break in maintenance and while I have the bike down I would like to lower the front of my bike.
Is this advised? I am going for street/strip and I am not concerned with high speed cornering. I have tools and time, just need advice/opinions.
Fire away, Gentlemen!
Last edit: 17 Mar 2012 22:56 by H-60MGuy. Reason: spelling error
- Thank you received: 2829
17 Mar 2012 23:40 #510318
by 650ed
Replied by 650ed on topic How can I lower the front of my 85 GPz? Should I?
It will handle like crap, but if you don't care ............... :dry:
- H-60MGuy
17 Mar 2012 23:58 #510330
by H-60MGuy
Replied by H-60MGuy on topic How can I lower the front of my 85 GPz? Should I?
Thanks 650Ed. I will keep this in mind.
- mark1122
- Keep twisting it
- Thank you received: 109
18 Mar 2012 12:11 #510416
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic How can I lower the front of my 85 GPz? Should I?
the easy way would be to loosen the top and bottom tripple trees at the forks. then raise the forks in the trees. i dont see how it will make it handle like crap, but u will loose clearance.
it will turn into corners easier.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- DFIGPZ
- Thank you received: 122
18 Mar 2012 19:51 #510504
by DFIGPZ
1984 750 Turbo
Replied by DFIGPZ on topic How can I lower the front of my 85 GPz? Should I?
Did you ever consider a tie down strap while at the track ? pull front end down for strip use then take it off r loosen for the street
www.schnitzracingstore.com/catalogs/cata...44216&showprevnext=1
1984 750 Turbo
