Installing an oil cooler on a kz750?
- chrispysaki
Thanks!
- jonnybravo
- Banned
- Thank you received: 18
- mtkawboy
- Thank you received: 16
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- dano83-1100
- 1983 KZ1100 LTD
- DoubleDub
- Visitor
- Thank you received: 2829
- steell
dano83-1100 wrote: The oil cooler that you can get does not affect the motor. It's air cooled...not oil cooled. in racing applications it keeps the oil for the clutch from boiling. It looks cool, I have one that was installed on my KZ1100 it's a yoshimura. It's possible that it might make a difference in really hot climates...I doubt it...as again these are AIR cooled engines. just my opinion.
Aside from being wrong, it's also irrelevant, an oil cooler cools the oil, nothing else, and the oil helps cool the motor. Oil gets really hot, and above 235f or so it will start to break down and lose it's lubrication qualities, and once that happens engine wear accelerates. In a perfect world the oil would reach 212f and stay there
- zed810
1981 z750e1 gpz 750a1 tank and side panels 810 bore kit web cams mikuni bs34 vance and hines pipe
- bountyhunter
- Thank you received: 337
The aftermarket coolers I saw which were "shunt" flow had a restrictor orifice that allows only a small amount of oil out through the cooler and back to the oil pan. Very little pressure tapped off the high pressure output of the pump.zed810 wrote: your forgetting that installing a cooler onto a bike that did'nt originally have will cause a marked drop in pressure
- bountyhunter
Oil coolers were REALLY important when these bikes were built (70's and 80's) because in severe service the oil additive packages went away really quickly meaning 10-40 oil turned into 10W oil after a few hundred miles.
Oil additives are a lot better today, and if you really want something tough: just get a true synthetic and you can get it as hot as you want. The engine parts would melt before the oil breaks apart.
- zed810
