valve clearance
  • bobbisman
  • bobbisman's Avatar Topic Author
valve clearance
13 Mar 2012 22:52
#509497
my manual says correct valve clearance is 0.15 but is this just a maximum number or is this where is should be exactly. only one valve allowed a 0.15 mm feeler gauge and the rest were either 0.12 or 0.10. i guess im wondering if i should be looking at smaller shims from whats in there now? im gonna double check these #'s cause i was kind of in a rush. thanks again
  • baldy110
  • baldy110's Avatar
Re: valve clearance
13 Mar 2012 23:20
#509501
What bike are you working on? That seems to be a rather large clearance. My GPz1100 engine are set at between .03 to .07 thousands clearance. .15 does not sound right. Usually the manual will tell you between several numbers as long as the clearance is between those numbers you are fine.
Re: valve clearance
13 Mar 2012 23:32
#509506
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future. And may be changed whenever and as often as desired.
Attachment addsig.jpg not found
Good Fortune! :)
Re: valve clearance
13 Mar 2012 23:40
#509509
Z1 valve clearance spec is 0.002~0.004 in. (0.05~0.10 mm).
Some folks recommend an exhaust valve clearance up to 0.15 mm.
Good Fortune! :)
  • bobbisman
Re: valve clearance
14 Mar 2012 08:13
#509546
lol. i guess that info would probly be useful. 1978 kz 650b. clymer manual is where i got the clearance from
  • timebomb33
  • timebomb33's Avatar
Re: valve clearance
15 Mar 2012 00:46
#509750
i always set my clearances the same .004" on the intake and .006" on the exhaust side or at least as close to that as i can geti set them a bit looser than factory because i'm basically lazy and i only check my valve clearances once a year or so unless its my race bikes, if you run web cams they call for .006" on both sides. looser is better than tight if you can't get right at .006" then go looser don't go tighter.
I THINK MY POWERBAND BROKE
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: valve clearance
15 Mar 2012 22:18
#509918
You can run intake clearances at .05mm or .002" just fine, exhausts at .075mm or .003"
IF - IF you check them at regular intervals thruought the season.
If your inclined to just set and forget for a while, you can go as large as .015mm .006" or more if u can stand the chatter.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Re: valve clearance
15 Mar 2012 22:29
#509922
bobbisman wrote: lol. i guess that info would probly be useful. 1978 kz 650b. clymer manual is where i got the clearance from
Valve clearance should be between .08mm and .18mm. Anywhere near the middle of those two measurements is ideal, but as long as you are between them you're ok. Ed
  • trojan
  • trojan's Avatar
Re: valve clearance
27 Jan 2014 01:31 - 28 Jan 2014 01:50
#620192
I´m setting valve clearances on my KZ 1100 81´. I was thinking of setting all of the valves to 0,15 clearance (manual specs form 0,15-0,05mm) or would be better if i set exhaust valves to 0,15 and intake to 0,10?
Last edit: 28 Jan 2014 01:50 by trojan.
  • TexasKZ
  • TexasKZ's Avatar
Re: valve clearance
27 Jan 2014 05:07
#620202
Trojan, setting the valve lash to the smallest number will necessitate more frequent adjustments since the gap typically gets smaller as the valve and seat wear. I cannot imagine that setting the intake valves below spec to start with can produce good results. An old-time kz drag bike builder once told me that these engines run best when the intake valves are adjusted to the middle of the range, and the exhaust valves at the loose (biggest number) end.
The following user(s) said Thank You: trojan
  • trojan
  • trojan's Avatar
Re: valve clearance
28 Jan 2014 02:10
#620321
Sorry; my mistake. Service manuale states clearances from 0,15 to 0,05 (not 0,5). So 0,10 for intake is on the middle and 0.15 for the exhaust on the loose side.
Thanks!!!, will set them like that :)
  • jeffasaki
  • jeffasaki's Avatar
Re: valve clearance
28 Jan 2014 04:26
#620324
i make notes
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
