new rider....up a creek
13 Mar 2012 20:53 #509473 by blu.sky716
new rider....up a creek was created by blu.sky716
Hey!
I recently purchased a 81 Kawi kz440 as a starter bike. Went to take a look at it Saturday, looked great and started right up first try. Returned on Sunday, bought the bike, rode it roughly 30 miles back to my place and parked it where it sat until today. Today I started it up and rode it down the driveway, out onto the road.....where it died. Tried restarting it, wouldn't start.
I thought the tank was empty so I refilled it, still wouldn't start.
I thought it was oil and dumped in some that a friend had handy (Thank God!), still wouldn't start (D'oh!)
Any suggestions for starting the bike? Or what could possibly be wrong with the bike? I'm going to try cleaning out the fuel tank (rusty) and cleaning the carb (can't hurt can it?)
ramble on,
Blu.sky
13 Mar 2012 21:00 #509477 by ramtough_63
Replied by ramtough_63 on topic new rider....up a creek
rusty tank aquals clogged carbs equals wont start.
look and see if the previous owner has an inline fuel filter it could be clogged if not unscrew the drain plugs in the carbs if no gas comes out they are stopped up. as a diagnotic tool only let stick a pocket screw driver in ther and it may start running out let it run til it runs clear and then try to fire it up.
either way probably gonna need a carb clean
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
The following user(s) said Thank You: blu.sky716
13 Mar 2012 21:05 #509478 by ramtough_63
just my .02 I like to try and isolate the problem before tearing anything off I have seen alot of problems exasperated by pulling stuff off and fixing it before it is determined thats what needs fixed. good chance its the carbs but could be something as simple as plugs.
first determine if its the fuel like you suspect. then check for spark.
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • bluej58
13 Mar 2012 21:41 - 13 Mar 2012 21:42 #509484 by bluej58
Replied by bluej58 on topic new rider....up a creek
Good advise.
Also be careful what oil you dump in there.
kzrider.com/forum/2-engine/506892-re-kz7...st-engine-oil#507054
JD
78 KZ1000 A2A
Last edit: 13 Mar 2012 21:42 by bluej58.
13 Mar 2012 21:58 #509486 by 650ed
Replied by 650ed on topic new rider....up a creek
Is the petcock turned on? Ed
13 Mar 2012 22:03 #509487 by ramtough_63
I never use my run off run switch on my goldwing accidentally turned it off once took me 3 hours of diagnostics and a coil removal to figure out i had shut it off lol
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
13 Mar 2012 22:11 #509490 by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic new rider....up a creek
:laugh: Petcock on and killswitch! Those are gotchas! Happens to the best of us...or so I've heard!
Kinda curious what made you think of the oil, not my first choice.
'81 still had a manual choke, have you put it in the "Start" position?
Does the bike turn over?
13 Mar 2012 22:50 #509496 by blu.sky716
Replied by blu.sky716 on topic new rider....up a creek
Hey guys!
The petcock has three setting RES ON PRI (counter clockwise) I tried starting the bike on all three, but upon further investigation realized that fuel never came out when I tried to start it in the ON and RES but some squirted out when I tried the 'PRI' setting. Kill-switch was definitely on RUN each try (That's on the right handle bar correct?).
I dumped some oil in because the little window on the motor showed there was no oil in there.
As for the choke, I'll have to check because I'm pretty sure that it was in the 'on' position when I first started the bike today, but after it died no variation of choke positioning would help. There could possibly be a 'start' mode I hadn't seen before.
Thank you all for the quick, helpful responses! As a new rider, I am much obliged!
Ramble on,
Blu.sky
13 Mar 2012 23:29 #509504 by Patton
Replied by Patton on topic new rider....up a creek
With the bike parked (engine not running), and petcock in PRI position, loosening the carb drain screw should allow fuel to freely flow from the float bowl. Under these conditions, the fuel is supposed to exit from the end of the overflow hose; but if the overflow hose is missing, the fuel should exit from the nipple located on the bottom of the float bowl.
This simple test will determine whether fuel is traveling from inside the fuel tank to inside the float bowls.
Good Fortune! :)
14 Mar 2012 00:47 #509523 by Link14
Replied by Link14 on topic new rider....up a creek
One other thought....sounds like you have a vacuum petcock (my '79 kz400 did). This means you shouldn't get any fuel from the petcock unless the engine is turning over and drawing a vacuum on a vacuum line that runs between the petcock and a nipple on the discharge side of the carbs. If this has kinked or fallen off, you won't get any fuel flow.
14 Mar 2012 00:50 #509524 by ramtough_63
Link14 wrote: One other thought....sounds like you have a vacuum petcock (my '79 kz400 did). This means you shouldn't get any fuel from the petcock unless the engine is turning over and drawing a vacuum on a vacuum line that runs between the petcock and a nipple on the discharge side of the carbs. If this has kinked or fallen off, you won't get any fuel flow.
do all of your testing on prime as patton said fuel should flow freely on prime
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
20 Mar 2012 18:52 #510893 by blu.sky716
Hey everyone!
Sorry for the delayed response. Finally had a nice enough day for me to go outside and check out the bike. I ran the carb test on prime as recommended by Patton and fuel does trickle out from both float bowls. Any other ideas? I'm still lost as to what may be the issue here.
ramble on,
Blu.Sky
