quick answer needed. 1000 jug fit 900?
  • shadow44
  • shadow44's Avatar Topic Author
11 Mar 2012 19:20
#509087
Can some one tell me for sure if a 1015cc jug will fit on my 903cc lower end. and is there any difference other than the bore dia. I just tore mine down and it appears one of the liners is cracked. I dont want to spend the money to have it bored to find out its a crack not a scratch. There is a guy selling on craigslist a 1015cc KZ1000 jug and piston set. Do I persue that or will it not work.... He is selling cheap so I need to act fast.
Remember, the government can not give you anything they have not first, taken from someone else.
  • peter1958
  • peter1958's Avatar
Re: quick answer needed. 1000 jug fit 900?
11 Mar 2012 20:11
#509099
yeah that will work
The following user(s) said Thank You: shadow44
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
11 Mar 2012 20:55
#509108
You may have to dremel open your 900 cases for the 1015 jugs to drop right in (a few places...nothing major). Sometimes the jugs drop right in, sometimes not.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • zed1015
  • zed1015's Avatar
11 Mar 2012 20:56
#509110
1000 block will fit but some 900 cases need the case mouths enlarging for the liners to drop in.
It's only a mill or so front and back and can easily be done with a file.
  • Kapahulu
  • Kapahulu's Avatar
12 Mar 2012 02:52
#509175
If the case holes need enlarging I think you need to take the motor apart to keep the metal filings from going inside. Correct me if I am wrong.
2strokeworld.com
  • zed1015
  • zed1015's Avatar
12 Mar 2012 07:19
#509183
Can be done with a file with the engine in situ but very carefully and slowly with plenty of greased rag in the crankcase mouth to catch and hold the filings.
Success would be down to the competance of the individual.
