What lines are everyone using for oil cooler?
- dejavoodo41
09 Mar 2012 11:37
I'm getting ready to put an oil cooler on my bike since the weather is starting to warm up here in FL and was wondering what lines you are using? I'd prefer to have something braided not the plain black lines that I've seen on some bikes.
Thanks in advance,
Roger
Thanks in advance,
Roger
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- gengomerpyle
Re: What lines are everyone using for oil cooler?
09 Mar 2012 16:03
mine are steel braided but they were on the bike when i bought it
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- StreetfighterKz
09 Mar 2012 16:48
I'm not sure exactly what you want except "not the plain black lines." Follow
this link
and there should be a few options for you.
Hope this helps.
Later, Doug
Hope this helps.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: dejavoodo41
- MFolks
09 Mar 2012 17:21
Oil Coolers & Accessories
www.batinc.net/mocal-central.htm
www.holley.com/types/Temp-A-Cure%20Oil%20Coolers.asp
www.z1enterprises.com/Oil-Cooler-Fitting...0-KZ900-Z1-4520.aspx
- dejavoodo41
09 Mar 2012 21:19
Thanks for the replies. I think what I may do is just go to he Harley Shop down the street and see what they have or go to JP Cycles since they are only about 30 minutes away. I know that they had some oil line kits the last time I was in there so maybe I can find what I'm looking for there. I know that they were the only ones in town that had screw in valve stems when my front one went bad....lol
- Old Man Rock
09 Mar 2012 21:39
3/8ths....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- dejavoodo41
09 Mar 2012 21:46
Thanks, I've got a cooler on the way and I've had the adapters for the lines for close to a year so I figured I'd better get on this.
- notaduc
09 Mar 2012 21:46
-6an (3/8 id) Aeroquipe starlite.
1980 (mostly) KZ1000
09 Mar 2012 23:19
As perhaps already considered, braided lines will quickly abrade any painted surface that they come into contact with.
- TomW
- Keep the blue side up.
10 Mar 2012 17:21If you route them between the center carbs and over the top of the engine it wont matter what color they are. You can't see them very well. That's how mine are arranged. The Kerker thermostat is mounted on a custom bracket behind the coils and the oil lines run along the backbone.dejavoodo41 wrote: I'm getting ready to put an oil cooler on my bike since the weather is starting to warm up here in FL and was wondering what lines you are using? I'd prefer to have something braided not the plain black lines that I've seen on some bikes.
Thanks in advance,
Roger
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
- dejavoodo41
10 Mar 2012 20:09
I was actually just thinking about running them like that. I'm more than likely not going to be running a thermostat since it doesn't get that cold here in Florida. Thanks for all of the input guys. I'm sure I'll get it figured out.
- notaduc
11 Mar 2012 21:24
I plan to go over the top also, and point my in/out fittings up as to make sure the cooler doesnt drain when the the bike is sitting.
