Stumped ???? Help
- Bored
put it all back together but for the life of me cannot get thw timing right followed the manual to the point were i thought it was printed wrong no matter what i do it will not time And now i have bent two more valves Really pissed off at the point need another idea i honestly think its the wriong cam chain but it all built back up and the only way of checking lenght by counting links or stripping it apart again i i had hair id be ripping it out by now thank u in advance rant over
Bored
- steell
- baldy110
- Thank you received: 512
Did someone replace your engine with something else in the past or did you break a chain?
- steell
- baldy110
- Diesel-Dr.
the number of chain links doesn't matter as long as the chain fits. the gearing is all in the sprockets the chain is just used to connect the sprockets together.
- H-60MGuy
- 1985 GPz 750 Streetfighter
We got it right the first time, using the factory manual.
If you post some pictures of what your cams look like when you have it "in time" based on cam gear positions and crankshaft position, I'm very confident that someone here can guide you in the right direction.
"See, what had happened was.........."
- TorreyJ
- Thank you received: 1
- elfmagic17
- Thank you received: 24
TorreyJ wrote: you can't be 360 degrees off. that makes no sense. stop, step back and think about what you're saying. it makes no sense.
"I turned Right four times and I'm still in the same place!!" :blush:
When in time, top dead center no 1 and 4, your end cylinders cam lobes will point at or away from each other depending on which cylinder you look at, if that helps.
Kenny Hicks
74 Honda CB550
- Diesel-Dr.
- TorreyJ
- TorreyJ
