Hi. Is around 2mm side play on starter clutch on secondry shaft on kz 650 normal. Also the 2 thrust washers each side on needle roller bearing for s/c have a slight shamfer on 1 side of inner circumfernce 1 side. Does shamfer go against n/r bearing. Any advice much appriciated. Great forun.
Cheers Dave
