rebuilding starter
- busted knuckle
rebuilding starter
17 Feb 2012 15:41
I am rebuilding my starter and have it all apart and noticed that there is significant grease and small amounts of debri in the yoke assembly. What can I do to clean this part of the starter?
1979 kz 750 b4
The following user(s) said Thank You: Kraz1
Re: rebuilding starter
18 Feb 2012 13:38
I'm not sure what you mean by yoke assembly, but I'd bet that a bottle brush and some electrical contact cleaner or warm soapy water will giter done.
- KraZyRIDER
18 Feb 2012 16:36
...you could also try a can of brake clean with a straw on the nozzle. That should blast anything unwanted out of the way and it also evaporates quickly.
Mean Green Speed Machine!
1979 KZ 650-C3 (Cafe Project)
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
18 Feb 2012 18:26
Bake cleaners will work, however, if you are outside the People's Republic of Kalifornia, there is a good chance the brake cleaner will contain 1,1,1-trichloroethane, which can do bad things to certain plastics and synthetic rubber compounds. Proceed with caution if you use this stuff and be sure to use it outside. It is bad stuff and you don't want it in your eyes or on your skin.
