torque v. stretch
torque v. stretch
11 Feb 2012 15:19
In another thread, I saw a discussion about replacing all the nasty, soft engine cover screws with stainless allen head bolts. One of the posters mentioned that torquing the new fasteners is really important. I don't disagree, but wonder about the torque spec.
As I understand, a torque spec is really just a lazy man's way of measuring stretch. For example, in the fsm for the ZRX1100, there is no torque spec for the rod big end bolts. Kawi prefers to measure the stretch of the bolt. If that is not possible, then Kawi recommends tightening to 11 ft-lb, then rotating the nut another 120 degrees.
My question about the KZ case bolts is this, since the originals are soft aluminum, and presumably stretch very easily, then would it be proper to use that same spec on much less stretchable stainless steel?
- faffi
Re: torque v. stretch
11 Feb 2012 19:56 - 11 Feb 2012 20:00
Some bolts have properties that makes them very flexible, more like a rubber band. Others will snap before they stretch much. Torque specifications are usually to make sure something doesn't leak and/or fall apart without disturbing the shape and/or snap treads. If you overtighten the bolts on the engine covers, your greatest risk is stripping treads followed by disforming of the cover itself, which can cause leaks. Stick to the recommended values, or a little less if you use paste on the treads.
If you can measure stretch and know that the bolts in question are factory AND unused, it will give the most accurate torque setting because it will be oblivious to friction - which can vary enormously, giving false torque values. Unless otherwise specified, torque settings are for dry bolts with fresh treads. Lube will lead to overtightening, bad/rusty to undertightening.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
1980 F1 engine
B1 Points ignition
Last edit: 11 Feb 2012 20:00 by faffi.
11 Feb 2012 20:14 - 11 Feb 2012 20:16TexasKZ wrote: In another thread, I saw a discussion about replacing all the nasty, soft engine cover screws with stainless allen head bolts. One of the posters mentioned that torquing the new fasteners is really important. I don't disagree, but wonder about the torque spec.
You have been mis-informed; none of the original KZ fasteners are not soft. They are steel, not aluminum, so the torque spec for allen head bolts is the same as for the original JIS screws or cap head bolts. Picture below shows 2 original clutch adjuster cover screws held by magnet. Ed
Attachment IMG_2771.JPG not found
Last edit: 11 Feb 2012 20:16 by 650ed.
- LarryC
11 Feb 2012 22:17 - 11 Feb 2012 22:18
You guys over analyze things to death sometimes
It's a frigging cover bolt. If you can't tighten one of those by hand without a torque wrench.....then you probably shouldn't even be using tools :woohoo:
Larry C.
Last edit: 11 Feb 2012 22:18 by LarryC.
- andy9802gt
- If it tastes that good, eat it yourself.
11 Feb 2012 22:34LarryC wrote: You guys over analyze things to death sometimesIt's a frigging cover bolt. If you can't tighten one of those by hand without a torque wrench.....then you probably shouldn't even be using tools :woohoo:
AMEN to that brother Larry! I get tired of hearing about torque specs all the time on stuff that you can do by feel. Cover bolts, spark plugs, valve stem caps, when will it end? Oh by the way, does anybody know the torque spec for rim screws?
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- dshelly
12 Feb 2012 00:02650ed wrote:TexasKZ wrote: In another thread, I saw a discussion about replacing all the nasty, soft engine cover screws with stainless allen head bolts. One of the posters mentioned that torquing the new fasteners is really important. I don't disagree, but wonder about the torque spec.
And the carbon steel that the stock Phillips head screws is NOT the same as the stainless that the allen head cap screws are either. So the "stretch" would be different. However, Like Larry says, just tighen it by hand and forget about it. No need to anal-ize this stuff to death.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- Boostable
12 Feb 2012 00:10LarryC wrote: You guys over analyze things to death sometimesIt's a frigging cover bolt. If you can't tighten one of those by hand without a torque wrench.....then you probably shouldn't even be using tools :woohoo:
That's freaking hilarious!!! But damn.. so true!
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
The following user(s) said Thank You: PLUMMEN
- ramtough_63
12 Feb 2012 00:13
fully seated not stripped
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
12 Feb 2012 00:29 - 12 Feb 2012 00:30
dshelly wrote:
And the carbon steel that the stock Phillips head screws is NOT the same as the stainless that the allen head cap screws are either. So the "stretch" would be different. However, Like Larry says, just tighen it by hand and forget about it. No need to anal-ize this stuff to death.[/quote]
There are no Phillips screws on a KZ; only JIS screws.
Anyway, I believe the torque question was intended for folks using the allen bolts because believe it or not there are many ham-handed owners (not named Ed, Larry, or Andy of course) who using a ratchet can and will strip out the threads in an aluminum engine by overtightening allen screws and you're right, they should not be allowed near hand tools. I know this to be true from working on BSA's that had the good ole allen bolt treatment. BTW, I use JIS screwdrivers, and no, I don't use a torque wrench on JIS screws (I'm lucky enough to be too old and weak to strip the threads using a screwdriver). Ed
Last edit: 12 Feb 2012 00:30 by 650ed.
12 Feb 2012 00:48
When attaching the engine covers, only the foolhardy would consider anything besides an original genuine Black Forest brand torque wrench. These wrenches have no equal, and are scientifically calibrated to the precise German Virgin Standard, which in most applications specify the Guttentite setting.
It's high time to move beyond the time-honored Arizona Redneck technique of "Twist until it strips, then back off 1/2 turn."
- Garn
12 Feb 2012 02:07 - 12 Feb 2012 02:08
Here's one..... Do you put more torque on a bolt with anti-seize or moly compound on the thread and under the head of bolt/ screw surface.
RegardZ.
Ps. Agree 6mm threads don't need a torque wrench.
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Sydney Australia
Last edit: 12 Feb 2012 02:08 by Garn.
- LarryC
12 Feb 2012 09:23 - 12 Feb 2012 09:36
Here's a good example for you all.
The rear axle nut has a torque spec. It's also in many cases and castle nut and the axle has holes for a cotter pin.
So when you torque the castle nut to spec and the holes in the axle don't line up with the castle nut, what are you going to do....
a] Get out the Drill
b] Take it back apart, rotate the axle a tad and try again
c] Try using a shim behind the nut
:whistle:
How tight do you tighten:
* the screws for the handle bar switches?
* the nuts on the cable adjusters?
* How tight should the seat latch grasp the lock bar on the seat?
* turn signal and tail light lens screws?
* the caps on the valve stems? [some are plastic - some are metal]
* the screw on cover of the brake master cylinder
Sometimes you just have to
and hope for good results
:whistle:
Attachment images_2012-02-12.jpg not found
Larry C.
Last edit: 12 Feb 2012 09:36 by LarryC.
