any idea how?
  • Dboy78kz1000
  • Dboy78kz1000's Avatar Topic Author
any idea how?
07 Feb 2012 03:37
#502494
i am having a hard time getting my oil pan off any ideas?
  • nobody
  • nobody's Avatar
Re: any idea how?
07 Feb 2012 03:52
#502497
did you over look any bolts ? maybe hit it with plastic hammer to break seal ?
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: any idea how?
07 Feb 2012 04:14
#502500
Remove ALL the bolts and whack it with a rubber mallet on the flat spots (not angular to the fins).
If that doesnt jolt it loose, you can wedge the tip of a knife blade in there and pry gently a little, repeating the process carefully around the pan edge. Try not to gouge the gasket surface.
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Dboy78kz1000
Re: any idea how?
07 Feb 2012 11:42
#502549
i pulled all the bolts from oil pan. i just got a new rubber hammer my old one was no good.so ill go try the knife trick and see if that works.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: any idea how?
07 Feb 2012 12:35
#502560
Dboy78kz1000 wrote: i pulled all the bolts from oil pan. i just got a new rubber hammer my old one was no good.so ill go try the knife trick and see if that works.
The first time I pulled off an oil pan from my 1977 KZ1000A1, I also couldn't remove the pan...there are 17 bolts (I only removed 16 and was attempting to pry off the cover when I realized I missed one). If you have 17 bolts, then pry away :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • dshelly
  • dshelly's Avatar
Re: any idea how?
07 Feb 2012 13:46
#502572
Don't forget the filter cover. That hold it on too.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • Dboy78kz1000
Re: any idea how?
08 Feb 2012 03:57
#502748
ok so i got the oil pain off looks pretty good if u ask me. ill have pic up in a few.
