oil pressure switch
- busted knuckle
oil pressure switch
03 Feb 2012 00:07
my oil pressure switch on my kz 750 is stuck on. Will using pb blaster or wd 40 or a propane torch damage the switch? how much force can i use to try and break it lose?
1979 kz 750 b4
- jonnybravo
- Banned
- Old Man Rock
Re: oil pressure switch
03 Feb 2012 07:29
Uhm can't say for the KZ750 series but the KZ900/1000 series the upper switch housing is plastic...
Thus, No likey heat torch.... Melt long time.... :blink:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- rstnick
03 Feb 2012 21:36
Have you tested the switch?
Just wondering, as my 650s oil light has come on a few times, and each time it was the wire comming off the switch was grounding to the engine, thus iluminating the oil light.
A bit of electrical tape around the wire where the back edge of the points/pick up plate had worn through the wire's insulation fixed it up (turned off the oil light).
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
