Shift shaft oil leak
- jrjstuff
01 Feb 2012 13:41 #501320
by jrjstuff
Jeff
83 KZ750 ltd
Shift shaft oil leak was created by jrjstuff
Hey guys, its been awhile since ive posted but its rebuild time soooo here I am again! I have a terrible oil leak from the shift shaft on my kz750 ltd. Do I have to split the case in order to fix that leak?
Thanks for your help in advance!!
Jeff
83 KZ750 ltd
- baldy110
- Thank you received: 512
01 Feb 2012 15:03 #501333
by baldy110
Replied by baldy110 on topic Shift shaft oil leak
If you confirmed that the shift shaft seal is where the leak is coming from then, no. That is a really easy fix, drain the oil, remove the sprocket cover, pry out the old seal with a small screwdriver and replace with a new one.
- Thank you received: 1656
01 Feb 2012 15:16 - 19 Feb 2013 12:53 #501335
by martin_csr
Last edit: 19 Feb 2013 12:53 by martin_csr.
- ramtough_63
01 Feb 2012 15:24 #501338
by ramtough_63
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Replied by ramtough_63 on topic Shift shaft oil leak
my 1000 is leaking there also
I think I have to remove the trans door to peplace
Attachment 100_245202.JPG not found
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- jrjstuff
01 Feb 2012 15:44 #501346
by jrjstuff
Jeff
83 KZ750 ltd
Replied by jrjstuff on topic Shift shaft oil leak
Where should i get that seal? Z1?
Jeff
83 KZ750 ltd
- ramtough_63
01 Feb 2012 15:46 #501347
by ramtough_63
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Thats where I am ordering mine from friday. they have a seal kit for the 1000 comes with several seals I need not sure if it's the same for yours or not
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- jrjstuff
01 Feb 2012 16:55 #501359
by jrjstuff
Jeff
83 KZ750 ltd
Thank you guys! Ill be looking for that at Z1 today!!
Jeff
83 KZ750 ltd
- Hollywoodmx
01 Sep 2013 12:57 #604300
by Hollywoodmx
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Replied by Hollywoodmx on topic Shift shaft oil leak
I cheated on this one, not sure it will work. I took an oring a little smaller than the shaft, put liquid gasket on the area and pushed the oring on top of the liquid gasket. We'll see if it works! :pinch:
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
