- Thank you received: 4
MPG's Does this sound right??
- Flyndrive
30 Jan 2012 11:21 #500839
by Flyndrive
1980 KZ 550A1
1985 GPZ 900R
MPG's Does this sound right?? was created by Flyndrive
I am only getting about 33 mpg and it just seems a little low for my bike. The bike runs great but at 100 mile my tank is empty. Spark plugs look good light tan color.
STATS:
1980 KZ 550 A1
4-1 Kerker
Pods
Jets 32/95
Sprockets 16/40
Rear tire 130/80/18
Front tire 100/90/19
Type
6 speed, constant mesh, return shift
Clutch multi-disc, wet
Gear ratio
1st --2.57
2nd --1.78
3rd --1.38
4th --1.13
5th --0.96
6th --0.85
Primary reduction ratio--2.94
Final reduction ratio--2.50
Overall drive ratio--6.25 @ top gear
The gearing calculators are just a little different than what I'm getting.
6th gear/ 67 mph/ 6000 rpm (if I remember right)
I'm wanting to bring my rpms down while on the Highway. Was thinking about changing front sprocket to a 17T.
STATS:
1980 KZ 550 A1
4-1 Kerker
Pods
Jets 32/95
Sprockets 16/40
Rear tire 130/80/18
Type
Gear ratio
1st --2.57
2nd --1.78
3rd --1.38
4th --1.13
5th --0.96
6th --0.85
1980 KZ 550A1
1985 GPZ 900R
- roy-b-boy-b
- Thank you received: 103
30 Jan 2012 14:11 #500860
by roy-b-boy-b
Replied by roy-b-boy-b on topic MPG's Does this sound right??
I don't know much about the little bikes but I think you should be getting better fuel mileage than that. I think I would try a larger front sprocket. I always go for the cheapest fix first. Roy
- DoubleDub
- Visitor
30 Jan 2012 14:16 #500861
by DoubleDub
Replied by DoubleDub on topic MPG's Does this sound right??
Pods and kerker and a happy right hand could mean 33mpg. :whistle:
I have a huge range depending on whether I'm commuting around town or on the highway most of the time.
- Flyndrive
30 Jan 2012 14:30 #500864
by Flyndrive
1980 KZ 550A1
1985 GPZ 900R
Replied by Flyndrive on topic MPG's Does this sound right??
I'm kinda wondering if its me being 6'5" 250 with sometimes a heavy right hand every once in a while. but most of the time its just highway riding 60-65. Almost every tank is the same. I hope changing the sprocket will help.
1980 KZ 550A1
1985 GPZ 900R
- faffi
- Thank you received: 36
30 Jan 2012 14:56 #500874
by faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
Replied by faffi on topic MPG's Does this sound right??
Weight and size definitely matter, but it seems you are running fairly low gearing - stock they turn around 5000 rpm @ 60 mph IIRC. That may have a small impact. So you're big, gearing is short, chain may be a bït stiff, tyres a bit low on pressure, brakes dragging slightly and jetting not ideal for frugality = 33 mpg easily. Stock, with tiny journalist testers and a frisky throttle hand they delivered mpg in the low 40s.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- Powerstroke_fan
- Thank you received: 83
30 Jan 2012 18:31 #500910
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic MPG's Does this sound right??
what size chain does it run a 630?? or 530???
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- baldy110
- Thank you received: 512
30 Jan 2012 19:33 #500931
by baldy110
Replied by baldy110 on topic MPG's Does this sound right??
Just to put things into perspective here, before I crashed my KZ650 I was getting about 40 mpg @ 80 mph. My specs were 720cc big bore kit, pod filters 4 into 1 pipe, 17 tooth front sprocket and 42 tooth rear. 130/80x18 rear tire, 100/90x19 front. My carbs were stock 24mm mikuni's with #15 piolt jets, 115 mains and the needle in themiddle slot. The bike got great gas milage, I'm 6-01 and 185.
I would think you should be getting better that that.
- Flyndrive
30 Jan 2012 19:47 #500934
by Flyndrive
1980 KZ 550A1
1985 GPZ 900R
It a 530 chain.
I think it should be doing better too, I've seen all these other bikes getting 40-50. Maybe it's just under powered for hauling my big butt.
1980 KZ 550A1
1985 GPZ 900R
- DoubleDub
- Visitor
30 Jan 2012 22:42 #500992
by DoubleDub
Or running rich. It's hard to use the plugs as an indicator with the fuels we have nowadays.
I dealt with a float height issue that was causing poor MPG performance too - caused me to run rich and also dump some fuel from time to time out the overflows.
- RonKZ650
- Thank you received: 240
31 Jan 2012 01:36 #501033
by RonKZ650
Replied by RonKZ650 on topic MPG's Does this sound right??
I had a new GPZ550 back in 1981 and got 60mpg and I'm 200+ lbs. So you are not doing great on MPG for sure.
- loudhvx
- Thank you received: 1616
31 Jan 2012 04:02 - 31 Jan 2012 04:06 #501040
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic MPG's Does this sound right??
Yeah, definitley not right. Your jetting is not even a whole lot different from stock. If anything, I would have expected you to be slightly lean.
The 40 rear will reduce your mileage a tiny bit, but not much. Stock should be a 38. Your RPMs at 65 mph will be about 300 RPM higher than stock.
I would check to make sure both of your wheels spin freely. If they drag, it may be time to rebuild the front caliper or inspect the rear brake.
I'm not sure if the GPZ 550 gets better or worse mileage than the standard A1, but I have a Kerker and pods and get between 60 and 70 mpg if I stay light on the throttle on the highway.
The KZ550 A standard has a slightly larger tank than the KZ550 D Gpz, and the gpz can get 200 miles before reserve (as tested in 1981).
1981 KZ550 D1 gpz.
Other links.
Last edit: 31 Jan 2012 04:06 by loudhvx.
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
31 Jan 2012 06:35 #501046
by andy9802gt
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Replied by andy9802gt on topic MPG's Does this sound right??
My bike gets about 35mpg so I would be really dissappointed by getting less than that on a little old 550.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
