throttle cables
  • C 3 rider
  • C 3 rider's Avatar Topic Author
throttle cables
29 Jan 2012 20:46
#500746
The throttle cable on my bike will not snap back, when u open it up, it returns very slow. I tried openeing the throttle right at the carbs and it snaps right back. Is the problem most likely in my cables?
79 KZ 650 C3
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: throttle cables
29 Jan 2012 20:49
#500750
sounds like your cables. if you dont see and spots where the coating is bad or broke and the cable is not frayed you could try oilling it. if not might have to buy new.
1977 KZ 1000 work in progress
  • MFolks
  • MFolks's Avatar
Re: throttle cables
29 Jan 2012 20:52
#500753
Your cables need lubrication & check to see if the return spring is working(usually on the carbs).
The motorcycle accessory stores sell a cable lube kit consisting of a can of spray lube, and a special clamp dsigned to fit on the cable ends. It's a real easy job to do.
At worst, the throttle cables might need replacing due to sticking and binding.
Re: throttle cables
29 Jan 2012 20:55
#500754
Remove the throttle grip from the handlebars; open it up; clean it thoroughly including where the cables attach and the inside of the tube that fits on the handlebars. Then apply a liberal coating of white lithium grease to the inside of tube and the area where the cables attach. Lube the cables. You can do this by making a little funnel of aluminum foil or Saran Wrap, attaching it to the upper end of cable, and filling it with motor oil (there are also special devices for this, but I've never bothered with them). Let it hang like that overnight (do this with the clutch cable too). Be sure to put a small bowl or other container at the low end to catch excess oil that runs through the cables. Finally, ensure the cables are routed correctly. There should be no sharp bends in the cables. If this doesn't completely solve the problem your cables may be frayed in which case you should replace them. Ed
  • C 3 rider
Re: throttle cables
01 Feb 2012 22:17
#501429
They have been this way since I got the bike. When I changed to superbike bars I had them rolled to low and had to roll the cable elbows out to clear the gas tank which caused them to bind. So I rolled the bars up, moved the elbows back and now its like it has always been. I have tried lubricating but all I had was wd-40 and three in one oil. I also noticed a couple of cracks in the housing, so I've decided to replace them. It looks pretty simple where they hook in at the carb linkage, but how they connect to the throttle looked a little tricky to me. Any advice is greatly appreciated!
79 KZ 650 C3
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: throttle cables
02 Feb 2012 00:37
#501462
This post has some info on installing new throttle cables on the 650:
forums.kz650.info/index.php?topic=2366.0
Not really that difficult.
Do you have a workshop manual?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
