cam clearance???
- DoubleDub
- LarryC
Re: cam clearance???
24 Jan 2012 08:40On the valve cover.....take out those + marks. That will suffice.
Don't get way down in the lifter bores. Put the left side caps #1 & #3 on the cams when you spin check them. Those are the thrust control caps. Force the cam all the way left...spin it....then all the way right & spin it.
It's a tedious job to do and make it look good with a hand tool.
Larry C.
The following user(s) said Thank You: DoubleDub
- Powerstroke_fan
24 Jan 2012 10:54
Iam just using diffrent shapes of grinding stones for a dremel can buy them at wal mart like $2 a piece. Dont forget This is a J model head. So mine dont have the t marks. I only took what i needed off the edge off the lifter bores, towards the top. i didnt go in the bores. so what the rule of thumb for clearing a j model valve cover, Since there isnt the t marks? thanks
1977 KZ 1000 work in progress
24 Jan 2012 13:07
- Powerstroke_fan
24 Jan 2012 17:57
That head looks good did u clearance it yourself?
24 Jan 2012 18:02
no sir,
it is a pic from the net to demonstrate the way it should look.
- DoubleDub
- saxjonz
- KawboyZ
24 Jan 2012 18:34You should try the worm bits. They will work much better without having to change out bits so often.Powerstroke_fan wrote: Iam just using diffrent shapes of grinding stones for a dremel can buy them at wal mart like $2 a piece. Dont forget This is a J model head. So mine dont have the t marks. I only took what i needed off the edge off the lifter bores, towards the top. i didnt go in the bores. so what the rule of thumb for clearing a j model valve cover, Since there isnt the t marks? thanks
79 LTD B3
- APE Jay
24 Jan 2012 18:41Powerstroke_fan wrote: The head is off the bike. The cams are a 418 lift. same as the old andrews 3x cams. I just went with ruffly .026" clearance using feeler guages.I just put the feeler guage in there oiled and roated the cam by hand. If it wouldnt rotate fairly easily i took more out so thats what i mean by ruffly.
Be careful running those cams with shim on top.
- Powerstroke_fan
24 Jan 2012 21:56
I have never heard of "worm bits". i will see what i can find online. I will be running shim under buckets with these cams. I read about the problem they have of lifting the shim, sounds to risky to me to take a chance with shim on tops but thanks for the information. Ill take all the help i can get.
24 Jan 2012 22:42DoubleDub wrote: But you could show us one of yours...right?
doubledub,
i haven't clearanced a head for big cams.
yet! :evil:
i did not stumble on that pic by chance,i have spent some time thinking about the best way to machine those with the capabilities i have.
when we trench banshee cases for big stroker cranks we have to do the same type of machine work.
only on a larger scale,and only have to cut two bores.
grinding them out is just fine tho.
all you need is some clearance,and no one can see them after the cam cover is on.
- Breaker19
24 Jan 2012 23:13Powerstroke_fan wrote: I have never heard of "worm bits". i will see what i can find online. I will be running shim under buckets with these cams. I read about the problem they have of lifting the shim, sounds to risky to me to take a chance with shim on tops but thanks for the information. Ill take all the help i can get.
I believe the write is talking about die grinder bits, here's an example:
Die Grinder Bits
2003 Suzuki DR650 Dual-Sport
1982 KZ1100A2 - GONE! Traded-in for a '12 Concours 14
www.facebook.com/pages/Moto-Resto/169238286503527
